-   -   Trouble locating a new fan pulley nut (http://forums.pelicanparts.com/porsche-911-technical-forum/486556-trouble-locating-new-fan-pulley-nut.html)
ninelevenick 07-20-2009 05:18 PM
Okay, what the heck is going on here? Has no one ever cross-threaded a fan pulley nut? I cannot find a supplier for this nut! Today I managed to bugger up the threads on the 16mm by 1.00 pitch jam nut that holds the fan pulley in place. I have visited a hardware store, a fastener store, an auto parts store, called a Porsche dealer and an aftermarket Volkswagen Beetle specialty place as well as looked on Pelican, but I cannot find this simple little nut! Do any of you have a source?
88911coupe 07-20-2009 05:43 PM
Ordered mine from our host.
boyt911sc 07-20-2009 05:49 PM
16 mm x 1.0 Alternator nut........
Visit you local starter/alternator repair shops. You might get lucky and get it for free. HTH.
Tony
Gogar 07-20-2009 05:55 PM
I got a 16 x1.00 nut from AAA metric in Denver:
http://www.aaametric.com/
They DO NOT have jam nuts, but they have regular depth nuts. So, it will work, but won't be 100% "proper."
80-911SC 07-20-2009 06:42 PM
try pelicanparts.com new part search , alternator or give them a call i think they have an 800 number
ninelevenick 07-20-2009 07:35 PM
Oh, an alternator pulley nut. That's the right terminology. Thank you for your replies. I ordered one from our host.
Gogar 07-20-2009 07:59 PM
Where did you find it here on PP? Because I'd love to have the proper one, but everywhere I find it it shows up as $NLA. Unless 74-81 "Marchal alternator nut" will work.
Thanks!
SmileWavy
SpeedracerIndy 07-20-2009 08:24 PM
Here's my story on that nut: http://forums.pelicanparts.com/porsche-911-technical-forum/452834-there-way-repair-threads-alternator-shaft.html?highlight=alternator+nut
Long story short, the 16x1.00mm are NLA, while the later 17x1.5mm are readily available. I still have a spare alternator with repairable threads but I couldn't find a replacement nut for it.
Good luck and let everyone know if you find a suitable (grade 8) replacement.
ninelevenick 07-20-2009 10:20 PM
Well that's interesting. I ordered part #928-603-904-00-M262 Marchal Alternator Nut. If you click "more info," it says "911SC / Turbo (1978-1983) (from 82)" Hmm...does this imply that the part is compatible with a 1978-81 car with an '82 or newer motor?
WilsonTC 07-20-2009 10:38 PM
That nut is 17x1.5
ninelevenick 07-20-2009 10:45 PM
Unfortunately you're right. Who knew that a puny nut would be so difficult to get?
Rot 911 07-21-2009 06:22 AM
Feel free to flame away, but when this happen to me I just rethreaded it to the closest SAE size which I believe was 15/16 (still have the die if you want to borrow it). Picked up the die at the local auto parts store. Worked just fine. Think it cost me around $10 for the die and 50 cents for the nut. If you want you can try and get a thread chaser and clean up the threads to see if you can get the metric nut to work.
Hotrod911T 07-21-2009 07:19 AM
I had two rebuilt alternators and each had a different sized nut. I took the alternator with a cross-threaded nut down to an alternator rebuilding place. The shop had a box full of old alternator nuts and they just gave one to me.
Rod
ninelevenick 07-21-2009 08:03 AM
Kurt V and Hotrod, those are both great ideas. I thought of the possibility of re-threading to a more standard size last night. Kurt V, do you recall the thread pitch for the imperial thread size?
Rot 911 07-21-2009 08:08 AM
I will try to remember to go home at lunch and dig out the die from the tool box. I know it was a fine thread.
ninelevenick 07-21-2009 08:25 AM
Thank you, Kurt V, that will be great info for others having the same problem.
Good news for me! I just located a source close to me that has four 16m-1.00 nuts! Thanks to Hotrod who inspired me to call a good alternator shop.
Rot 911 07-21-2009 08:29 AM
If the price is right just buy all 4 of them!
c911s 07-21-2009 09:28 AM
I found M16 x 1.0 nuts at a local fastener outlet, after much searching. They had to be ordered in. Unfortunately the outside diameter is 24 mm not 22 mm so the alternator wrench does not fit. I am grinding down the flats to suit. They were not cheap, about $8 each. I bought a few, so if anyone needs one badly I can send one for about $10 incl mailing.
jimbauman 07-21-2009 09:32 AM
For this and a whole lot of other good metric fasteners, there is Mr. Metric in San Jose:
http://www.mrmetric.com/
JB
ninelevenick 07-21-2009 11:56 AM
I bought 2 nuts at $4.50 each, and they are exactly like the original. They said that they continually stock the nut, so it is a great source for all who live in and out of the area. They are a well established auto electrical supply and service company in Sacramento. Here's their main website:
http://www.lehrauto.com/
WilsonTC 07-21-2009 01:12 PM
Post a part # (if available) so anyone searching in the future can locate/order.
SmileWavy
ninelevenick 07-21-2009 01:34 PM
Good idea. The part # is RB 85-2697 for the 16M-1.00 jam nut found at Lehr Auto.
