Carl83911's Avatar
Identifying turn signal relay.
Ok, before someone replies with "GO TO SEARCH", I already have and found several topics on the subject but did not answer my question.
I took my fuel/oil pressure gauge and found a relay with 6 blades. I believe that is the seat belt relay (is this correct?)
The turn signal/hazard warning flasher relay has 3 to 4 prongs. Is this correct? If not behind the aforementioned gauge, where else could it be?
thank you.
Carl,
Old 07-21-2009, 04:40 PM
You're looking in the right location and should see the flasher relay which is black, looks like a "tall cube", and has four prongs.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 07-21-2009, 05:20 PM
