-   -   how do you adjust the hood<front>... (http://forums.pelicanparts.com/porsche-911-technical-forum/486598-how-do-you-adjust-hood-front.html)
ertech 07-20-2009 08:19 PM
Hi
how do you adjust the front hood so it sits lower at the back < where the windshield is>so I get a better contact with the seal.
ertech 07-21-2009 07:52 AM
is there an adjustment for that part??
blee 07-21-2009 08:25 AM
The bracket, where it attaches to the body, pivots. Loosen the bolts slightly, close the lid and you should be able to push down on the corners.
ertech 07-21-2009 09:15 AM
Thanks so much
KevinP73 07-21-2009 09:26 AM
You can also add one washer per side on the forward most bolt between the hinge and the hood. It's a little faster than trying to rotate the hinge base.
