Order of assembly ... Ball style end links
I am working on a bit of a project ...
Making adjustable end links from Ball style to newer style sway bar. The order of assembly is: nylon bushing in end link, then use a BFH to pop that on the ball or the other way round ??? |
YMMV, but I would install the ball socket receive last. You don't need a BFH. Instead, a long crow bar will allow you to lever the socket onto the ball. It helps to do this with a loaded suspension (as on a wheel alignment lift or by rolling the vehicle onto a few of layers of 2x10's).
Sherwood |
perfect ... thanks
| All times are GMT -8. The time now is 10:11 AM. |
