-   -   Advice on Dropping Front Spindles (http://forums.pelicanparts.com/porsche-911-technical-forum/486669-advice-dropping-front-spindles.html)
haasad 07-21-2009 05:00 AM
Any experience regarding dropping front spindles on a 911 strut. Wheer to grind through the welds, where not to grind, re welding, addtional bracing and steering alignment after.
Thanks in anticipation.
andy
Walt Fricke 07-21-2009 03:01 PM
Andy
Are you prepping the car for the Baja 500? Transyberia?
Folks usually want to raise the spindles, not drop them.
You can raise the Bilstein strut spindles, because the main strut tube is a constant diameter. Grind the welds, raise it up, reweld. While you are at it, why not weld in some reinforcing tabs, as the factory did for the RSRs.
The Boge spindles really can't be raised. For some reason the housing tube is necked down at the bottom, and the spindle is at the top of the neck. You'd have to machine the ID of the spindle to get it to fit. Come to think of it, maybe that would work. I'd not want to turn the tubing down.
While it is easy to say "grind/drill out the welds and move the spindle," I think a big press might help. My "beat it with a hammer" methods resulted in the ball joint mounting piece being smashed to uselessness. I didn't care, as the strut tubes were kinked and useless.
I've considered cutting a section out of the top of the housing just below the threads, and welding the threaded portion back. Then cutting the tube below the spindle, and welding in the section I cut out, or some other suitably sized piece of tubing. I have had success with sectioning the top part on my '68 style struts (success means the welds held), but haven't tried this with the later struts. or down low where the stresses have to be a lot greater.
Walt Fricke
haasad 07-22-2009 09:14 AM
Sorry yes raising them ! I am happy with the grinding and re welding just looking for pitfalls and while you're ther stuff. What doe the strengthening mods look like?
feelyx 07-22-2009 10:46 AM
Check JP's thread out here http://forums.pelicanparts.com/porsche-911-technical-forum/480047-koni-struts-raised-spindles-how-few-question.html it should answer some of your questions.
Tim
carrera turbo 07-22-2009 12:06 PM
i don't advise on dropping your spindles the impact could cause damage!
you should take better car when handling your spindles.
no sorry for the ribbing "im subscribed as i was wanting to know the same thing"
cheers ed
haasad 07-23-2009 01:17 PM
I would imagine dropped spindles in Alaska may result in frostbite !!
haasad 07-23-2009 01:26 PM
Had time to read the search thread now . Perfect and thanks. I'll be setting up my drill press with an end mill in the next two weeks.
andy
