pryord's Avatar
Ignition Timing for 67S
Dumb Question: Can someone tell me what pulley mark should be lining up with the pulley housing at idle and 6k rpm? I have marks for Z1, 30 and 35 degrees.
Thanks,
1967 S
Old 07-24-2009, 07:02 PM
304065's Avatar
I would use the 30 mark-- the 911S distributor actually uses less total advance than the Solex.
Can you actually get 30 at 6000? And still keep a decent idle? I found that before my cast iron distributors were restored the springs and advance pivots were so worn that I ended up with about 45 degrees of advance (fortunately no-load) at 6000. If I dialed the advance down I ended up with so much retard that the engine wouldn't idle. Ed Fall at Vintage Werks fixed all that.
Not too much advance! Good luck!
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 07-24-2009, 07:17 PM
