Burint's Avatar
ID the 1972 factory chassis stamped.
Hi guys
It's the vin fro the 1972 coupe US spec.
There's the brush stroke in black paint around it.
Was this done from the factory or it was recreated?
Burint
The Unbreakable RS/RSR door pull http://thaiporsche.shutterfly.com/776
86, 930.
70, 3.2.
67, 911.
Old 07-26-2009, 11:03 PM
HarryD's Avatar
Go over to the Early 911S Registry BBS. You will fund a ton of threads on determining if a VIN is ok or not.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 07-26-2009, 11:40 PM
If your question is whether or not someone at the factory painted the black paint on, and around, the serial number stamp, then I can tell you they did that. I have no idea why.
JR
Old 07-27-2009, 05:02 AM
djpateman's Avatar
You need to remember that the body shells were painted first, then stamped with the VIN in an unpainted rectangle. The black brush mark was to provide some rust protection over an unpainted surface. Is that 9112101306 I read there?
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 07-27-2009, 01:23 PM
