lowering
does anyone have step by step on how to lower my 911 sc
bwahahahahah... this is a good one!!!
...sorry it has been a long day... |
There's a guy who wrote a book with a bunch of projects for your 911. Lowering the car is one of the projects. I'm pretty sure it's called "101 projects for your Porsche 911" by Wayne Dempsey. You can buy it directly from Pelican Parts.;)
dumb question but how low ?
have you checked your ride height yet , take a tape and measure from the floor to the top of the wheel arch front and rear, also your tire size and post them please, a pic would not be a bad idea. |
100+ degrees in Oregon doesn't do any good until you have a sip of beer...and my brain started to work again...I think...
this is the ultimate thread you need: http://forums.pelicanparts.com/porsche-911-technical-forum/324765-time-replace-30-year-old-suspension-little-help-please.html?highlight=replace I enjoyed doing this project last year on my 84 chassis. Hope you do too. |
Once you change the ride hight you will have to re-align the car.
...........and go with 23/31 torsion bars. 930 brakes would also be helpful. Also think about the adjustable spring plates while you are there.....whoops forgot about the monoballs!! LEAVE IT ALONE!!!! It starts to get real expensive!! - - - - |
http://forums.pelicanparts.com/porsche-911-technical-forum/426585-home-alignment.html |
you can simply add additional weight to both ends of the car until it slumps down to the desired height.
Unless it's a pre-1983 car, why do you want to lower it?
| All times are GMT -8. The time now is 12:42 AM. |
