How to adjust knee pad??
Hi My knee pad needs to be aligned with the ashtray is this possible?if so how?
89 930 coupe
Old 08-02-2009, 06:23 PM
dtw dtw is offline
GAFB
There's two small nuts behind the dash which secure the kneepad. Loosen them and you will have a tiny range of adjustment to play with.
Several BMWs
Old 08-02-2009, 06:39 PM
great I get to them from the trunk?
Thnaks
Old 08-02-2009, 06:53 PM
dtw dtw is offline
GAFB
Nope, from underneath the dash area. Usually involves lying on your back with your head under the dash, with something unpleasant jammed under your shoulder blade. Feel around behind the knee pad until you have located the two nuts. Then get in there with a wrench. From memory, I know they are smaller than 10mm...try an 8mm.
Explaining the footprints on the headliner to your wife and/or girlfriend should be tons'o'fun.
Several BMWs
Old 08-02-2009, 07:01 PM
