-   -   Shift Coupling (http://forums.pelicanparts.com/porsche-911-technical-forum/4885-shift-coupling.html)
82SC 06-12-2001 05:21 AM
Shift Coupling
Well I am elbow deep into my Clutch replacement.
So while waiting for the Flywheel resurface, I am replacing the shifter bushings...the cup and linkage one were fine, but what is the deal with the coupling pair?
How do I get the old ones out?
Do I hammer the pin out?
I am confused...thanks for any advice...
I can't wait to see how my 915 feels with a new Sport Clutch, new shifter bushings...etc...
I may have to treat myself to a brand new shift knob!
JoeC 06-12-2001 05:30 AM
A little Wd40 and just hammer the pin out. Make
sure you support the coupler while striking the
pin. The coupler is cast and might bend.
Just did mine and I could not believe the difference it made.
Joe
78 SC
JoeC 06-12-2001 05:31 AM
Joe
78 SC
JoeC 06-12-2001 05:34 AM
Joe
78 SC
Allan Broadribb 06-12-2001 05:55 AM
I used a piece of 1/2" diameter aluminun, rod to drive out the steel pin with no damage. It came out without having to be hit too hard.
Allan Broadribb
'70-911E, 2.2l with Webers
http://www.cheaterswayside.com/uploads/Mvc-002s355.jpg
Early_S_Man 06-12-2001 06:07 AM
There is less chance of damaging the coupler body if you use a large bench vise, and a couple of sockets to press the pin out! On one side put a socket larger than the OD of the pin, and on the other side put a socket (1/4" drive) with smaller OD than the pin.
Warren Hall
1973 911S Targa
