My other ride is a C-130J
RNajarian's Avatar
1986 Tach Wiring Pin Out
I posted earlier with a problem getting my Tach to work after a 2.7 to 3.0 upgrade in my 1975 S. The original thread is here:
3.0 Upgrade from 2.7 Tach Issues
My question is; I currently have four tachometers (one from a 1975 911S, one from a 1983 SC, and two from a 1986 Carrera) does anyone know how to wire up the 1986 tach into the 1983 SC motor setup?
I have the +12 wire, the Ground, and Can get a Tach drive signal from the Coil
Can you drive the tach directly from the coil? Does it put out too much milliamperage? will the coil burn out the electronics of the tachs?
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic
2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer
Previously Owned Art from Stuttgart
2000 Boxster -1983 911 SC Cab -1984 944 N/A
Old 07-31-2009, 08:11 AM
