-   -   Trans Shift Help Needed-- Can't Shift.. (http://forums.pelicanparts.com/porsche-911-technical-forum/488746-trans-shift-help-needed-cant-shift.html)
scmguru 07-30-2009 06:56 PM
I went to park my 86 930 this evening and when I went to select reverse, I felt a bit of a pop and noticed I wasn't feeling the tension when I push to the left on the shift knob.
The shifter will not move into 1st, 2nd or reverse. No grinding, it just won't budge more than say a few MM or so regardless whether the car is on or off, clutch in or out.
3rd and 4th are totally fine.
I checked the shift coupler linkage and I'm spot on, I just can't select any gears on the driver's side of the shift tower.
Any suggestions before I have her flat bedded to the shop? Car is stuck at a friends. :mad:
Thanks!
Mike
yelcab1 07-30-2009 07:41 PM
check the linkages and coupler. After that, you may need to open up the tranny.
scmguru 07-30-2009 08:21 PM
Rear coupler is adjusted properly. Is there another linkage that I should check? Where is the spring that gets pushed in to engage reverse located?
Thanks!
yelcab1 07-30-2009 08:43 PM
It is underneath the shifter, inside the shift housing. You access it by removing whatever middle console you have and then pull up the carpet.
Matt Monson 07-31-2009 06:29 AM
When you start the car and release the clutch, is the car in reverse or neutral?
kodioneill 07-31-2009 06:53 AM
Take off the small rectangular cover on the side of the transmission and see if the bracket is tight and attached.
scmguru 07-31-2009 08:21 AM
Neutral, won't go into reverse.
Off to the shop it goes..
