Flywheel warning
We did 1986 911 clutch job,,new flywheel..routine job..no start..replace crank triggers.they were original 55k..no start..after 2days of insane rececking repulling the engine..the reference mark allen bolt in the new flywheel is non ferrous???????????replaced with steel..car fired right off??????? Hopefully this will help one of you guys when this happens to you!!! And it will someday...murf
Old 01-09-2012, 12:17 PM
I've seen this probably in 4 clutch jobs. First on mine Reference Sensor gap - Rennlist Discussion Forums
and on several others. My solution was to re-install the old flywheel bolt.
Old 01-09-2012, 12:27 PM
i posted about that a year ago. enough to piss a guy off.
206 637 4071
Old 01-09-2012, 12:49 PM
