oil for marelli
where do i place the oil to get it into the shaft? what about the grease? lobes- advance weights? thanks
steve
Old 08-05-2009, 04:50 PM
HarryD's Avatar
I do not know about Marelli's but every other distributor I have ever worked with, had a plug in the shaft where the rotor goes. You remove the rotor, pull the plug, dribble in some light oil and replace the plug.
For the lobes, you put a dab of Bosch Distributor Grease (a tube will last you a lifetime) on the points lobe.
Do this every oil change.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 08-05-2009, 06:58 PM
