Favorite greases
The grease issue came up when I was looking for a high quality grease to lube my polybronze bearings. This is one of those areas that seems rather simple , but once you start to do a little research you find it is not so simple after all. I am probably over thinking it.
Ever heard of green grease?
Please list your favorites for chassis and bearings.
Scott
73.5 911
74 914 2.0
Scott S.
Old 08-04-2009, 12:55 PM
Senior Member
Superman's Avatar
The toughest-duty stuff is the high pressure moly stuff. Used on CV joints. That is what I lubed my polybronze bushings with, and that is what I suggest.
Other, lesser moly grease is available in a can and is cheaper. Still very good grease.
White lithium grease is decent, but not for high pressure applications. This is the common grease used to grease all sorts of parts that see friction, but not much friction. It is largely not water-soluble, so it stays in place longer than others.
But the real stuff to use in non-high-pressure applications that will never see grease again (window cranks, door locks, blah blah.........is that sticky, waxy, stringy amber-colored stuff.
Mocha 1978 911SC. "Coco"
Old 08-04-2009, 02:11 PM
AutoBahned
RWebb's Avatar
search up the Chemicals thread
Old 08-04-2009, 02:18 PM
304065's Avatar
Krytox
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 08-04-2009, 02:32 PM
Recreational User
porschenut's Avatar
Will the green haired kid with the nipple rings at Autozone know what that is?
Old 08-04-2009, 03:27 PM
Originally Posted by john_cramer View Post
Krytox
Superb product (nothing better!) but VERY expensive and VERY toxic to handle. Special gloves and cleaning solvents are required to safely use that stuff.
Another excellent option is Neo,.........
We use both, depending on the application.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 08-04-2009, 04:37 PM
nineball's Avatar
Old 08-04-2009, 05:17 PM
I am thinking just a good lithium complex, moly and graphite fortified grease with good specs. LB GC grade. This should be fine.
Thanks for all the replies.
Nineball: I hope for the sake of humanity that you had to search to find that picture. There may be an issue if that was your desktop.
Scott S.
Old 08-04-2009, 06:28 PM
nineball's Avatar
yep. google images rocks. but in the rare chance that you wanted to save a copy for yourself i found it at http://www.stuffwelike.com/stuffwelike/wp-content/uploads/2008/09/john_travolta_in_grease_wallpaper_2_800.jpg
i did have a thing for rizzo though in my younger days...
Old 08-04-2009, 06:31 PM
