What is smallest under body sway bar?
What is the smallest under body front sway bar and what rear sway did it come with.
I know the early 3.2 Carrera was 21f & 18r. Where the SC's or late 2.7's smaller and what size were they. |
74 911's used 18mm, front & rear. The 911S had 20mm front & 18mm rear.
Correction: 84-85 3.2s had 20f/18r and 86-89 models had 22f/21r.
My 73S had 15mm front and rear from the factory.
Thanks guys. What I needed.
Need to double check.
Is there a 18mm under body front sway? I thought the bars through 76 or 77 were through the body (trunk). |
I have a 74 with the under body unit; that's when the change was made.
Thank you for the confirmation.
| All times are GMT -8. The time now is 09:55 AM. |
