95 993 gillett heat exchangers on a 3.2 euro
Hello,
Will the above bolt on to a euro 3.2? What muffler should I use (I have the euro factory one now and would like to keep the sound similar). What other parts will I need for the back date of the exhaust and install on the 3.2? TIA, Scott
72 911 T Targa in Orient Red / Black - more like a 85 Euro RS IROC now - 85 Euro 3.2 with x-faktory EFI ITB + SSI + Dansk, 915 + Wevo, flares + IROC bumpers + duck tail, RS door panels, Corbeau LG1 microsuede seats, Speedware harness bar + drop links + Scroth DOT harnesses, adj Tarett sways, sport shocks, alloy trailing arms, Elephant Racing oil lines + spring plates + bushings, RSR Rota Foxes + Bridgestone S-04 PP, 2450 lbs |
Need to rotate the flanges on one of them.
Instant-G sells the "happy crab II" muffler that will work with them, and can also do the flange rotation for you. You'll need a back-dated oil crossover pipe to work with them, but that should be all you need. |
MBruns for President
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
What diameter are the 993 header primaries? 1 5/8? 1 3/4?
Gone 92 C2 82 Euro SC race car 993 C4S 3.8 84 Euro Carrera |
Doug Crossman #92 1992 964 PCA G class #902 1979 911 PCA 911 Cup 96 993 Targa |
