-   -   Gruppe R conversion (http://forums.pelicanparts.com/porsche-911-technical-forum/490105-gruppe-r-conversion.html)
Johneracer 08-06-2009 09:59 AM
Gruppe R conversion
I am in the process of converting my early 911 w/2.4L S motor w/carbs to a stock 3.2L motor. Does anyone have a blueprint of what needs to changed?
B D 08-06-2009 10:11 AM
To do it like an R Grupper just take it to a good mechanic like TRE and pay them to do it.
Just search "motor swap" and you will see many threads on the subject. Which trans do you have and what do you plan to use?
Johneracer 08-06-2009 10:59 AM
It has a 915 w/factory limited slip. It has all the trick suspension pieces but will be used as street rocket and occasional track car.
911pcars 08-06-2009 03:08 PM
I suppose two basic types of hot rodders: Check book owners and DIY owners. One's satisfaction from writing checks or building it yourself can be the same, depending on the owner.
There may be different perspectives from others, but from a personal point of view, it's up to you.
Sherwood
Scooter 08-06-2009 03:14 PM
Stock? You mean with Motronic? This is a very big question that needs to be answered before anyone can answer your original question.
Johneracer 08-06-2009 04:29 PM
This is a stock 3.2 with original computer management system and harness.
Macroni 08-06-2009 04:53 PM
Is your car a matching number S?
If so I would review the economics of your decision. Ss tend to be valuable. A 3.2 conversion makes a bit more sense in a T. The S motor is valuable also.
I have a 73T w a 3.2L. The car is a hoot..... Light, nimble, quick very cool.
The complete fuel system, wiring harness have all been updated to 3.2 vintage and compatibility. The car services as if it were a 3.2 carrera.
Suspension: SC front suspension and brakes, adjustable spring plates, 22-28mm t-bars, turbo tie rods, bump steer, new rubber bushings, fenders rolled riding on 7/9X16s, Oil cooler w/ aeroquip lines, SSIs, 7:31 geared.
