R Gruppe#756
help ID these motor case's
I'm trying to determine if these case's are of any value....
I know it's early stuff but any help would be appreciated. thanks. 1ST ![]() 2ND ![]() 3RD ![]()
Post the engine serial numbers near where the fan goes. You will find the serial # on the side of the casting for the fan and just behind it on the top of the case, the engine type number which will be 3 numbers then two more like this xxx/xx. The numbers you posted were casting part numbers and not directly relevant to answer your question.
You could do the same with the tranny cases. Numbers on the bottom.
Tony G 2000 Boxster S |
Engine #'s
![]() If the engine is a 2.0 then there is also the build # to provide, next to the type #. This is an early engine with the serial # facing out, but by mid 1968 the serial # faced the side.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 Last edited by djpateman; 08-07-2009 at 08:47 AM.. |
