3.2 w 915 Clutch seems grabby
Totally stock 3.2 84 Cab with 112,000 mi. I replaced the clutch assembly at 65K due to a failed clutch fork. Has and does work great EXCEPT when I am in reverse lately the clutch seems to not grab gradually like it does taking off in first gear. It is either "on or off" so to speak. Do I need to adjust the clutch down below or am I just looking at a wearing out clutch plate?
1984 3.2 Cab (now toy) 1975 911S (old toy) Mercedes E350 W4 (snow car) 2007 911 Turbo (water and air pumper) 2012 Panamera 4S (for the wife, I swear) |
bump
It's hard to dignose without actually trying it out but I would suggest that you adjust the clutch cable at the transmission. If it doesn't grind going into the gears, you should be able to adjust. Have you made any adjustments in the last 60,000 miles? If not, it will help.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Thanks, a small adjustment seemed to work just fine.
