-   -   CIS Gurus, need some help searching for clues.... (http://forums.pelicanparts.com/porsche-911-technical-forum/490425-cis-gurus-need-some-help-searching-clues.html)
skrufy 08-08-2009 01:44 AM
Hi to all the CIS experts-
First of all, thanks go to Paulporsche, Gunter, t77911s, and Ricks911S for the help and advice in making an adjustable WUR, done thru private emails as to not take up forum space/time.....
For the rest of all you smart guys out there- here are the particulars about my car that has sat mostly apart for 12-odd years for cosmetic paint and interior re-dye- new dash, headliner, rubber, sound proofing, etc- huge mistake! don't ever take your car apart, then have kids, move, remodel, move, etc......
'77 930 TC, 3.0ltr, 51k miles
-Euro exhaust, no smog
-SC cams
-intakes ported 32 to 36mm
-5 spd 915 box
-no intercooler, cockpit adjustable variable boost .75-1.25 bar, alcohol/water injection
-elevation 8000ft.....
periodically run at idle, fresh gas, stabil over the years.....
have just recently- last 4-5 weeks:
-fresh Amsoil, plugs and valve adjustment
-two new correct Bosch fuel pumps
-drained tank- removed, flushed, cleaned strainer, re-installed tank, blown out fuel
lines- no gunk, goo, crud anywhere in fuel system
-replaced fuel lines- Gates 300psi fuel injection hose- tunnel to rear pump, pump to
fuel accumulator- some external cracking, very stiff, so replaced.......
-new fuel filter
-new fuel accumulator- old wouldn't hold residual fuel pressure, dried up diaphragm
-rebuilt fuel distributor by Dale at Jaytan Industries, California- set for about 15%
more fuel at boost over stock......
-refurbished- ultrasonic, flow tested, spray pattern, polished fuel injectors - all okay by
John Hervey, Special T Auto, outside of Dallas, Tx
-Aux air valve checks ok
-no known vacuum leaks
-ignition good, spark, etc
-timing not touched after last tune up, about 150 miles and 12 years ago......
-cleaned, scuffed grounding points and all connectors in engine compartment and
trunk
-operating voltage good to both fuel pumps, WUR, and AAV. resistance in WUR heating
element for bi-metalic arm good
WUR- made adjustable plug, have disassembled twice, cleaned, diaphragm not cracked
flipped over diaphragm, set plug back to original position. have not moved bottom
plug under springs. fuel screen not blocked.....
I have the factory 930 manual......
the problem: doing the cold pressure test of the WUR per manual: today at 70f or
21c the cold pressure should have been about 1.1-1.5bar on a cold engine-
after bleeding the gage line of air, would consistently get way huge fuel pressure
at 70psi or 5.8 bar (my notes out in the garage- doing from memory so this may
off slightly.. was definitely 70psi....) this puts the starting mixture way lean I
understand, it will start after lots of coaxing, lots of smoke, have not driven it
under these circumstances.... knocking the plug down makes no difference- cold
pressure still way high.....
residual fuel pressure ok- in spec- fuel accumulator doing it's job- can't check
warm pressure- am pretty sure- until the cold is set.....
SSSSSSOOOOOoooo- is this WUR junk or could the fuel pressure regulator in the
rebuilt fuel distributor be off? if so, how to adjust it to control /lower the fuel
pressure? how to prove the WUR is junk- or good......
:(if this WUR is junk- which way to go?- would love to go digital, but I understand
the UT unit has growing pains to go thru yet software wise- not updated, still
using old serial ports/cables to connect the unit to laptops instead of USB ports/
cables (none of my computers have any serial ports.....), and you have to spend
several days programming- each data point, change one thing, have to go back
and change everything, all = not very user friendly, and I need real user friendly.
Any thoughts/ inputs would be greatly appreciated- or things I haven't checked or done..... I don't need a street rocket ship- just want it to be reliable and run right- we are soon to be running out of summer here in the high country of eastern Az....
thanks for all the usual support and corporate knowledge.....
Tim
mca 08-08-2009 05:08 AM
Are you sure you are measuring ccp? Sounds like you are measuring system pressure.
Tell us system, cold and warm pressures.
boyt911sc 08-08-2009 06:25 AM
Troubleshooting..........
Tim,
Double check your procedures for measuring control and system pressures. You might have inadvertently been measuring the system pressure instead of the control pressure as mentioned by Craig (MCA). However, one reason a WUR could register such a high reading is restriction on the return line. This restriction could occur be before or after the FD. A defective pressure relief valve could cause such flow restriction or a pinched section of the fuel return line. Keep us posted.
Tony
skrufy 08-08-2009 09:54 AM
more info-
thanks guys-
the high cold pressures are being measured between the FD- fuel distributor and the WUR per manual and the wonderful quality of pix in the manual..... my pressure tester is made with a simple T in the line, and then I bleed off the air by loosening the fitting just below the gage...... NAPA is supposed to have a real nice kit for about $120- the problem being the adapters- metric to SAE..... have 3 different combos of adapters to check the system pressure, cold/warm pressures off the WUR, and then pump pressures which is checked just prior to the aft fuel pump..... (2-4 bar is the spec here: below 2 bar- front pump is bad, above 4 bar, rear is bad.....)
I will go out this morning and re-measure everything and report back, starting with the system pressure between the fuel filter and the FD.....
I have checked the fuel return line to the tank- blown air thru and can hear it bubbling in the tank- that doesn't mean I suppose that there isn't a blockage and the air gets around it, as does the gas.... I have replaced the short fuel line from the "T" in the fuel return line to the bottom of the fuel accumulator...... have planned to replace the entire return line from the FD back to the tunnel connection, but ran out of fuel injection hose..... that hose, and all the others, seem to be okay, just 32 years old- ran a welding rod down the lines when I had them in hand- no blockage........ as I said, haven't found any real problems/crud in the fuel delivery system- replaced both pumps because I had them, and with as little as this car has been run over it's life, the old pumps run fine- will bench check their pressures, then sell them to somebody that needs them for some reasonable $$$.....
Am I incorrect in thinking that the cold pressure must be set first in order to get a valid warm pressure check? system pressure should be 6.0-6.7 bar for the '77 930- the numbers change slightly for the '78s....
as usual, thanks for help and tips..... the real solution ultimately, is to go EFI, but would like to keep it as stock as possible for the value..... some article is Excellence rated the 76-77 930s as collectable? had to laugh..... everybody in the 70-80s wanted wider tires, wheels, and flared fenders, and the Turbos had it all.... as stated earlier, I don't need to be the fastest Turbo around, and as far as I can tell, I have the only Turbo around in this part of remote high country of Arizona.....;)
Tim
Alpine, Az.
Wyvern 08-08-2009 11:14 AM
sounds very close to what I had.
with that high a pressure the WUR isn't doing anything (at least while cold)
The line form the wur to return system may be plugged.
I finally discovered this by leaving it disconnected.
It is hit and miss but to be sure the WUR is bleeding off pressure remove the pin from the spring (you can bench test it) or hook up the line from the FD and leave the return to tank line off. if fuel does come out of the return port on the WUR at least you know it is doing "something"
Then do that check with the pin in place (it just may be shutting the system off)
((Hitting the BIG plug would raise the pressure.))
I had mine fixed after many adjustments and WUR removals . but the 2nd to last (fixed) attempt I put the washer on the wrong side of the bi metal arm stud and duplicated my full system pressure issue.
It created no bleed off and after removing the blockage I knew it should have been OK. I stepped back (PMed tony) and redid the systems check. Swapped the washer and all pressures have been perfect since.
Sounds crazy but you want to set hot pressure first. (assuming the cold system can / could function correctly)
Then (often the next day or SURE it is cold) do the cold... then recheck the warm.
That system worked for me.
You WILL find it ...
mca 08-08-2009 12:01 PM
Tim,
Are you saying that your gauge won't allow you to measure system pressure? Sounds like your gauge doesn't have the valve which allows you to close the fuel path to the WUR - which measures system pressure.
JC Whitney has the gauge for $60 - best deal around.
Also, are you unplugging the electrical connection to the WUR? Be sure to do that.
Are you testing with the car running or are you jumping the fuel pump relay?
I believe that your WUR has a vacuum line that must also be addressed. My WUR has an atmosphere line so I don't have to apply any vacuum to get measurements.
Cheers,
Craig
skrufy 08-09-2009 01:22 AM
Been Dazed and Confused..... led zepplin
Well, it was and interesting day, and didn't get to fool around with the 930 until the afternoon....
thank you for the replies and info-
my fuel pressure tester does not have the selector valve at the 'T' in the middle of the test line- after bleeding the air out of the 'T' portion leading to the gage, the gage reads whatever pressure is between the end connectors..... is this not accurate enough? will look at the JC Whitney after this post- would be nice to have easy all metric connectors/adapters....
started on a dead cold engine for the cold pressure tests, WUR electric plug disconnected-
to get the pumps to run, I turn the ignition on, and then pull the plug from the connector next to the airflow plate- temp was about 70F, which should show a cold pressure of about 1.1- 1.5 bar- didn't bother to look at the exact graph page in the shop manual as the pressure shoots way past the spec and immediately goes to 4.8 bar/70psi....
as I see the book, I can't begin to check the warm pressure if the cold pressure is this far outta the ballpark...... put a c-clamp on the WUR to gently pull the plug down- no matter what, the pressure cold pressure goes to 70psi/4.8 bar :confused:
soooo, I then took off the gage and buttoned up the lines to the WUR. disconnected the input line to the fuel distributor (from the fuel filter...) at the inlet, connected my pressure tester in series with that line, bled the gage again...... then ran the pumps-
slam!- pegs my gage past 7.0/100 psi until the metal stop for the indicator needle....
I assume this to be system pressure- spec is 6.0-6.7 system pressure.....am I wrong in this assumption? this is the raw pressure off both pumps thru the fuel filter and accumulator..... tons of pressure to the fuel distributor.... am I in error in calling this system pressure??
took a break, came back in and read this thread again..... back outside, gages off the system pressure check, back over and reconnected to the WUR.....same 4.8bar/70psi
readings as before.......
then checked the return line from the WUR back to the fuel distributor as suggested by Wyvern- with 70psi on the input side, NOT A DROP OF GAS IS EXITING the return side!- took the short hose off, blew it out- no clog..... then took off the test gage hose to the WUR inlet to inspect the fuel screen- no crud there- blew the gas out with compressed air- no blockage that I can see, although the ports in the threaded blue metal portion of the WUR are rather small. then blew the inlet/outlet sides and don't get exiting air in the same volume as the input air- so maybe some obstruction??
obviously, the cold pressure at 70psi/4.8 bar will stay that high, because no gas is leaving the WUR to reduce the pressure.....
what next- pull the WUR and disassemble it for the third time? disassemble the thin diaphragm again, make sure there are no new clogs in the tiny ports?? OR IS THIS WUR JUST JUNK???
your thoughts are needed! it's late, there is something I'm probably forgetting to add here......
hopefully I'm have some more ideas from you/things to check tomorrow......
thanks again
Tim:eek:
boyt911sc 08-09-2009 02:54 AM
Wur........
Tim,
If you could not make the fuel flow thru the WUR freely when the engine is COLD, don't expect the car to start in the first place. As I mentioned earlier, the restriction in your WUR is either before the FD or a pinched return line after the FD. Even a good working WUR will have a very high cold control pressure because of flow restriction.
BTW, system fuel pressure is the pressure produced by FD in conjunction with the FP. A typical Bosch FP with flow rate of approx. 2 liter/min. is capable of producing 100+ psi of fuel. FD's pressure (relief) valve determines the system pressure and could be adjusted according.
First, test and investigate to locate where the restriction occurs. Disconnect the fuel return line off the WUR and allow the FP to run (very briefly) and be prepared to catch the fuel (in case it is not clogged at this point). Continue the test farther along the return line to the FD. After correcting the problem (fuel flow), then it is time to measure the cold and warm control pressure. Remember to record your system pressure too. Keep us posted.
Tony
skrufy 08-09-2009 11:51 AM
Sunday after noon testing......
Thanks Tony-
will attack the 930 after accomplishing a few "Honey-Do's"......
I will go test the fuel/system pressure on the line between the FD and the WUR- haven't made that configuration of hoses yet.....
last night, after loosening the return line from the WUR off the FD- I got no gas. zip, nada...... removed that short line, blew air thru it - a-ok....
then removed the return line/banjo fitting off the top of the WUR- still got nothing....
let the pumps run for several seconds with 70psi to the input side of the WUR-
no gas/ spray, etc- so the restriction has to be in the diaphragm area of the WUR....
any errors of thought here?
will report back......
Tim :confused:
skrufy 08-09-2009 08:20 PM
Dazed and Confused- part II
Hello all-
only had about 20 minutes today to fool with the recalcitrant 930 today...
back to last nights post: of course I have set the pressure tester between the FD and WUR- your basic set up for the cold warm tests..... a bit tired I guess....
what is strange- and I didn't do anything- is that I started to take out the WUR to disassemble once again to see if there was some identifiable blockage between the inlet/outlet ports.....
before doing that I took off the return line from the WUR to the FD at the FD.......
(remember, I did that last night in my post and got not a drip of fuel- even removed the return line from the top of the WUR and didn't get a drop while the input side was getting 4.8bar/70psi.....)
well today, before running the pumps, for grins I put the FD end of the return line in a plastic bottle- shazam!- Second Sinking of the Titantic- fuel big time.... connected the return fuel line back to the FD... installed the tester lines in between the FD and WUR again-
didn't bleed the gage as I was doing a quick check to see if the cold pressure is anywhere close to the ball park... 68.5f = about 20c = range of about 1.05-1.45 bar or so from memory..... turned the pumps on- wham, back up to 4,8bar/70psi......
so, back to square 1 minus 5...... without much doubt, need to get the JC Whitney gage kit for an easier install with valve at the "T" in the tester like the factory unit.....
still need to look for a blockage in the return lines downstream from the WUR I guess- don't know why last night equaled no gas from the WUR, and today the Great Flood...
as usual, any thoughts will be greatly appreciated..... should I just shoot the WUR, or the whole CIS...?
Tim
Dave27S 08-09-2009 11:40 PM
Hi Tim, i had a similar issue with CCP being far too high which i couldnt adjust. see http://forums.pelicanparts.com/porsche-911-technical-forum/480774-cis-frustration.html for more details. In the post you will find a simply test suggested by a pelican which is how i found my problem.
Paulporsche 08-10-2009 07:36 AM
You should set your warm pressure first. Do this w/ the engine off and the FP running. The correct Wcp should take less than 3 minutes to achieve w/ the heater wire connected. Stevemfr and Ricks911s have threads on how to do this, and I followed the procedure in my long WUR/CIS thread.
Make sure there is no obstruction @ the top of the large plug, under the fittings. There should be a small screen there. Sometimes they get clogged.
Once you get a correct Wcp w/ the Ccp plug up so that it has no effect, then you can knock the ccp plug down to the correct level (once the WUR has cooled down and the heater wire is disconnected).
TurboKraft 08-10-2009 11:17 AM
Cheap CIS test gauge =
NAPA Balkamp #700-1438
approx. $120
Has inn-line 90-deg valve, plus bleed valve (push button) under gauge.
Includes metric adapters that work perfectly on the 911 Turbos.
mca 08-10-2009 12:12 PM
approx. $120
Try this one from JC Whitney. Absolutely the best deal at $60. Fits our CIS cars perfectly. Has shut-off and bleeder valves too.
CIS Tester
skrufy 08-10-2009 01:56 PM
Have ordered the CIS tester for K-Jetronic from JC- hopefully will have it after returning from a trip this week/end so that I can get/give more accurate results w/ the switching valve..... the cheaper tester kit from JC looks exactly like the one I have..... which probably gives okay results- maybe, but much harder to deal with and w/o supplied adapters for metric compression fittings....
will play with my favorite CIS monster this afternoon if I get the time....
again, thanks for all the help....
Tim
Jim Williams 08-10-2009 05:50 PM
Tim,
Sending you a PM. Dave27S had a similar problem to yours, and the circumstances seem quite similar. You really should do a test involving your Fuel Distributor. It may not be the problem, but you need to rule it out before going off in other directions.
Dave27S, did you get your problem resolved?
azasadny 08-10-2009 06:56 PM
This post reminds me why I converted to Webers 3 years ago. My fuel distributir ended up being the main culprit, although my CIS was so badly butchered by past "mechanics" that we removed it and replaced it with the carbs. Tab Tanner did the work and rebuilt and installed the Webers and I haven't had a single problem with them since. Good luck getting the CIS sorted out.
Wyvern 08-10-2009 09:55 PM
Scrufy.
Maybe semantics but more than once you say:
"before doing that I took off the return line from the WUR to the FD at the FD....... "
There isn't a return line from the WUR to the FD.
Full pressure is delivered to the FD, there is a valve that then bleeds off working pressure back to the return to tank system.
The line out of the FD to the WUR send fuel to the gate keeper, the WUR.
if no pressure is bleed off at the WUR your working pressure will not be lowered.
The excess pressure excess is bleed back to the return system. and sets the working pressure so that your FD is at the needed pressures (cold or warm)
There should always be pressure coming out of FD through the line that goes to the WUR.
The WUR either lets out less or more pressure.
If no fuel comes out of the FD the problem hasn't even got to the WUR.
Fuel into the WUR but not out ... the WUR is doing nothing.
My "remove the pin" or even back of the disk screws in the WUR will point you in the right direction.
Right now I have $ on a WUR that is not doing anything (no bleed off) or the fittings going in or coming out of that WUR are the issue.
I worked on my buddies and below the built in screen there was blockage.
we removed the screen to find it but knew thats where the issue was.
Running like a champ as soon as we removed the screen / blockage.
If the line to the WUR (from FD) is removed there should be a fair amount of gas
If the line out of the WUR is removed the bleed of pressure will be great enough to have fuel come the other way from the return system.
If both of those are true ... your WUR is the issue.
Dave27S 08-10-2009 11:34 PM
Hi Jim, my problem was confirmed to be the rebuilt FD. The reworked FD is on its way back to me now - ive sent you a pm with futher info.
For skrufy, i would definitely do the simple test proposed by Jim in my thread above. It was very easy to do and confirmed my FD was at fault. prior to that i was going round in circles and was blaming the WUR. Jim also posted some great photo's so i think its worth a look to rule out the problem i had.
skrufy 08-12-2009 01:14 AM
Barking up the wrong tree.....?
Hi guys-
I feel a little guilty here in that I haven't had much time to play with the CIS from Hell, nor will I get back to it for the next 5-6 days..... in the meantime, you have continued to give good advise that I truly appreciate.....
Don't have the better tester I ordered yet- next few days after I left on business,,,,
To refresh everyone, the Car is a 3liter 930 turbo the rebuilt FD from Jaytan, fuel injectors reburbished, new filter and accumulator....
in my last post of testing result for cold pressuse, the values were way high at 4.8bar/70 psi, and I couldn't get it to drop no matter what- even making the WUR adjustable has not helped either....
So i read Jim Williams posts and CIS primer- and measure the fuel flow coming out of the FD to the WUR buy actually bypassing the WUR and dumping the fuel into a calibrated jar or breaker RESULTS SHOW FLOW RATES of 480cc in about 20 seconds. and therefore getting rates of 1440 cc in a minute.......
As I see it, the FD devilery rate has to be brought back into the specs of 160-240 cc min.....
seen to me I have been barking up the wrong tree by concentrating on the WUR instead of the FD....
Will call jaytan to see About getting this resolved. similar to Dave27s.
keep the cards coming
tim
Dave27S 08-12-2009 05:14 AM
Man, i feel your pain! this is identical to my issue. I sent you a pm as to what i found. Good Luck!!!
skrufy 08-21-2009 11:14 AM
Back to the Drawing Board....
Hello to all-
a quick update; after returning from a summer trip , and after getting my new pressure gages to verify what I have done previously-
Performed the "Checking Fuel Pump Delivery" test per the 930 Turbo Carrera Workshop Manual- Section 20, page 20-3:
this taps into the fuel return line to the tank after the FD- spec is minimum of
1170cc in 30 seconds, recorded about 1200-1205 cc in 30 seconds, test PASSES,
fuel pumps are good- both are new anyway.....:)
Next, performed the "Checking Fuel Delivery Rate for Control Pressure Circuit", page
25-14b..... this checks the fuel volume from the FD to the WUR... spec is
160-240 cc/ minute...
results: FAILS MISERABLY- performed twice, second time with better graduated
container: 1440 cc/ minute, then 1600 cc/minute- TEN TIMES the
minimum allowable spec!!:(:mad::mad:
The WUR can't possibly handle that volume, or pressure- which was off scale at over
100psi/7.2bar on my gage...... spec was for 73.4F=23C, cold pressure should have
been 1.25-1.65bar....
Called JAYTAN that rebuilt the FD in June- they said to send it back, which went out in yesterday's mail...... the FD he sent me was modified for someone trying to get 500HP
out of a CIS twin Turbo, highly modified engine for a 934.5??- they could only get 470HP with this one... He readily agreed that the volume/pressure was way too high, but since he hadn't heard from me, he assumed all was okay......:confused: he said he had my core still on the shelf, and would rebuild my old one to factory spec....:mad:
in the meantime, in all the above posts, I was chasing WUR gremlins... should have done this delivery test way earlier- :(:(:(- in the meantime, summer is slipping away here in the mountains.....
I asked, why would anybody spend all that money on such an engine- wanting 500HP, and not be done with all the CIS, and just go EFI? he didn't have an answer for that..
will post more when I get my 'rebuilt'- new FD back and installed again...
Thanks to all for the help...
Tim
Dave27S 08-21-2009 11:40 AM
Hi Tim, i closed my thread on the same problem and put up photo's on why my jaytan rebuild was doing the same as yours. you can see how mine looks like it was "modified" with a hammer and a naill. Hmmmmm, im not bitter at all.
hope you get resolution!
Paulporsche 08-21-2009 11:54 AM
Curious to see what happens w/ Jaytan. Dave's experience wasn't good.
Jim Williams 08-21-2009 02:21 PM
Tim,
The 930 fuel distributors have a working (system) pressure of roughly 95 PSI. You could still be near the right system pressure, maybe a little over, and peg your 100 PSI meter when you close the valve on your gauge set. (Working pressure on the 930 FD for the '86-89 is 102 PSI.) Yet the control pressure flow is still spec'ed at 160 - 240 cc/sec. Sounds like your rebuilder may still using a nail to control the size of the de-coupler hole in the diaphragm as was Dave's experience.
Personally, I can't see even on a whoopdy-doo FD for a 500 hp engine, one would need to exceed the 160 - 240 cc/sec flow rate for the WUR, as long as that flow can allow the WUR to control the proper range of pressures at the FD. The WUR does not provide fuel to the engine, so a higher than normal flow rate to the WUR should not be required. However, note that this is just my opinion.
skrufy 08-29-2009 12:29 AM
the CIS Nightmare continues- part 14.....
Update- the FD: aka boat anchor.... Friday Night 28Aug09
Well, the misery continues....... received my 2nd"rebuilt" FD from Jaytan Wednesday afternoon, which actually was my factory original FD used as the exchange "core" for the "1st" rebuilt FD, the one which failed as discussed in the above previous posts.....
I received #2 Wed. afternoon late, the 26th- installed it yesterday afternoon- went right to the "Fuel Delivery Rate for the Control Pressure Circuit" test:
Spec is: 160-240 cc/minute Result Test #1: about 795 cc/minute--- FAILS
Result Test #2: about 780 cc/minute-- FAILS
For grins, I checked the cold pressure which should have been about 1.1-1.5bar for
the temperature- Results: 4.8bar or 58ish PSI if I remember my notes
The WUR continues to drown with too much fuel- can't begin to work.....
Removed FD #2 an hour later- boxed it back up- shipped in today's outgoing mail:mad: back to Jaytan :mad:- which means they get it Mon/Tues- ship #3 back same time frame- update about this same time next week......
Dale at Jaytan agrees that once again it is too much fuel,
though roughly half of FD #1-rate of 1600cc/min.......
Dale at Jaytan says the punch used to give the correct size of the decoupler hole in he diaphragm may be broken thus too big = too much gas.....
He promises to get it right this time:(:(:(
that's it for now- anybody know of an inexpensive EFI system???
Tim:confused:
Jim Williams 08-29-2009 05:34 AM
skrufy sez -
Too bad... Maybe the third time will be a charm.
I think it's unfortunate that many times the CIS gets a bad name through no fault of it's own. Meaning that some "rebuilders" seem to have no clue of the tolerances needed by the system for it to perform as it was designed. "Uhh... that nail punch must be getting dull. You know, Bubba, the one we use to get the correct size for the Fuel Distributor diaphragm. Another customer is complaining about some fuel flow problem. We've got to look into that sometime. Maybe we should come up with a way to actually test these things before we send 'em out."
Or, perhaps easier, before they are assembled, find a way to make the hole the right size, or, maybe a go-no-go gauge to slip into the hole.
Or, find a diaphragm supplier that can make the hole, and to the specified tolerance.
Just my $0.02.
Dave27S 08-29-2009 11:27 AM
My THIRD time was not lucky. Looks like my experience with jaytan was not a once off. Seriously, what testing do they do on these before they send them out. No point sending it out for the customer to test and hope they get lucky.
im still trying to shake off the bitterness....
skrufy 09-01-2009 01:12 AM
tiny update.....
:( Monday 31Aug09
Talked with Dale at Jaytan today- so far he had not received my FD in the mail for examination/rebuilding. He said his punch for the fine di-coupler hole was indeed broken, and therefore making a hole too big = enough fuel to run a F16 at idle RPM..... he's gonna have to get that fixed he said...... told him to check the fuel delivery rate- remember, the spec is 160-240cc/min, before he send it back to me......:mad:
I wonder how many other bad Jaytan FDs are out there causing CIS cars to run erratically/inefficiently..... bad news and a horrible waste of time... fortunately California is just next door to Arizona, and not Ireland like Dave had to deal with during his headaches with Jaytan.... anybody else have bad experiences??
will post again with more breaking news as it happens!
Tim
skrufy 09-10-2009 03:19 PM
Overdue Update....
Swamped with other stuff..... thurs 10Sep09
when I last posted- had just talked with Dale at Jaytan last Monday about the problem child FD...
Rec'd the newly again repaired FD- my original- from Jaytan late the next day-1Sep- Dale got it that Monday afternoon- repaired and got it out via overnight air from California out here to the boonies of Az- must say, I can't complain about his effort to resolve my FD problem.....
Talked with Dale again Wed. afternoon- as I was installing it, he said his tiny hole punch was indeed broken for the de-coupler hole.... he fixed that, and performed his flow tests to the injectors.... I asked him if he preformed the "Checking Fuel Delivery Rate for the Control Pressure Circuit" test per manual (fuel rate FD to the WUR so it can function: spec is 160-240cc/ minute...) he said: "No, JAYTAN'S BENCH TESTER CANNOT TEST THAT FUNCTION!!!" got busy and haven't talked t him about results...
WOW!- such a basic feature of the FD and they can't do a quality control inspection of this important function before it leaves their facility! NO WONDER PROBLEMS EXIST WITH JAYTAN FDs!! I wonder how many other customers from all the other cars w/ CIS systems have had CIS headaches- shotguns aimed at WURs when the basic error starts with the FD.....
Immediately did the "Checking Fuel Delivery Rate......" test- actually have done it 4 times over the last few days as I checked/disconnected/changed stuff:
RESULTS: PASSED each check: (remember spec is 160-240cc/min)...
1. 195cc/min- figured all the chambers weren't full yet....
2-4. 215cc, 225cc, then 220cc/min- all close estimates from a molded
plastic container......
Next, rechecked the "Checking Fuel Pump Delivery" rate- tests fuel pumps as mentioned above- (spec is 1170cc in 30 seconds, minimum.....)...
RESULTS: PASSED, with about 1300cc- first test was about 1200cc... the neck on
my plastic graduated bottle starts to narrow after about 550cc with a final
mark of 710cc- so some interpolation is happening here....
next, played with the WUR- now adjustable?? the engine does run, starts after 5-15
seconds of playing with throttle, ignition obviously-ON, remote starter in engine
bay......
per suggestions in above posts, checked/ set the WARM pressure first, after
running engine for 10-15 minutes...
Temp: 62.6F = 17C: Cold Pressure range of 0.85-1.25bar
WARM Pressure spec, after COLD is set, is 2.6-3.0bar.... checked WARM
pressure, had about 3.3, then tapped WUR plug, reduced pressure/set it
2.75bar.......
Let 930 rest, cool down over night..... yesterdays temp: 64.1F = 18C, CP range
is .095-1.35bar ( I know, they are burning down in Tucson, boiling over in
Phoenix...) COLD pressure chimed in at about 0.70 bar, low, so adjusted
WUR plug back out and left it set at 1.2bar..... didn't get back to letting it
run/warm up to re-check the WARM pressure.....
System pressure is a bit low:(spec is 6.0-6.7bar) 5.6bar/81psi- don't know why
So, the WUR appears to be working/responding to adjustments....... other WUR stuff:
voltage to WUR yesterday was 14.65v, engine running, resistance to bi-metal
heater was 26.5ohms (spec on mine is 26ohms +/- 5%....), so heater is
working..... my WUR model number is different than 3 variants that came on
930s- was that way when I bought it 21 years ago or so.... ???
PROBLEM now- remember this car hasn't been run in 12+years, is I have a MISS at
idle, and all low rpm ranges:(...... have driven the 930 +/- a mile from the house, max 3000 rpm, 45mph..... the MISS is definitely there..... haven't isolated it yet- driving me nuts.....
-have swapped my new NGK plugs out (black, sooty from running so rich..) in case
one was bad, put cleaned old/but nearly new Bosch platinums back in- no
change
-have two spark testers- no definitive results, #1,2,3 so hard to get to w/ turbo
plumbing in the way- no change...
-installed new cap, rotor- no change.....
-plug wires are original- 32 years old- new Magnecors are on FEDEX for delivery
today, also distributor wire: connector has big crack/broken- have a new one
of those on same truck.......
-used a digital pyrometer/laser to check exhaust pipe temps- all in same temp
ranges- 460-487F, depending how steady I could hold the laser steady...
-have not done a compression check yet- Obama help me if there is a problem
there- never has been, and this engine has only been rev'd to 5-6k a few
times in the last idle 12 years....
Set up 6 clear tubes late last night to check the fuel flow rates from FD into 8 oz. jelly jars- ran pumps for 2 minutes, volume in jars about 2 oz each- similar, but with 3,4,5 getting a little bit more than the other injectors........ ran the lines off of the FD, as the
injectors are so hard/PITA to get to on the turbo side-1,2,3..... haven't had time today to recheck, as I had a few small dips in several lines that may have caused volume differences in several jars.....
IS THIS A VALID TEST of the FD rates? my thinking is maybe under pressure, one or two cylinders isn't getting enough gas??
I also used the spark check function on a small engine analyzer- wire pick-up by each plug: #2 spark was very slightly erratic, w/slight indicted rpm drop to #2, and audioburble/miss at idle, which leads me to think ignition vs. fuel.....
Any thoughts always appreciated- have to run errands, should have new plug wires sometime this evening, will install, and report..... also have clutch to adjust...
Tim
boyt911sc 09-10-2009 07:30 PM
FD delivery rate........
Skrufy,
A simple test is to measure delivery rate/s for each line/injector by measuring the amount of fuel delivered. First determine the individual amount of fuel delivered without the injectors installed and do another test with the injectors installed.
http://forums.pelicanparts.com/uploa...1252635570.jpg
A significant difference in the individual flow rate is undesirable and need further investigation. The Bosch FD is built and designed to produce uniform and consistent flow rate. Otherwise, your FD's integrity is in question. My two-cents.
Tony
skrufy 09-11-2009 12:46 AM
Tony-
great pix, thank you! my set up was similar using 59cents/foot vinyl clear tubing directly from the FD, BUT I can't test with injectors as you did because the injector lines on the 930s are steel...... would have to bend the lines bigtime to lift them up enough to get jars underneath them- do-able I guess for #4,5,6, but nearly impossible to get to on the #1,2,3 turbo side with all the plumbing in the way- then bending the lines back and hope to get them to fit somewhat easily..... so far, running the pumps with open ends in the jars seems to give equal fuel to all 6... will do it again-
Did it take several minutes of pump run time to fill those jars thru the injectors??
could do it easily if I had a set of the flex lines from a CIS 911- would really like to put any doubts about the FD/WUR to rest.....
the new Magnetor plug wires and distributor lead cable arrived this evening- will install
tomorrow if other duties don't get in the way..... am sure I will have to pull the distributor to install the new cable, which means moving turbo plumbing out of the way- a big PITA- oh well.....
hope that solves the misfire issue- will report back.....
Tim
Paulporsche 09-11-2009 06:35 AM
Are the turbo FDs adjustable for fuel pressure via shims? Maybe one more will give you the reqd pressure. Doesn't Jaytan's tester test pressure either?
skrufy 09-29-2009 10:32 AM
Swamped with other stuff- finally an update for all:
I installed the new Magnecor plug wires: the biggest issue with them or any new plugs I guess is that the "dust boot" for the distributor leads are very tight, and you have to make sure the wires are properly secured into the distributor caps...... they are fatter than the OEM braided wires, and to use the factory 3 wire rubber connectors, I just used a razor knife to neatly slice 3 cuts into the rubber wire holder, and then put the new wires in- they hold them just fine.......
THEN, no matter what, I couldn't get the car to start- started pulling my hair out, searching for everything, both fuel and ignition.....
Along with the new wires, I did install a new distributor signal cable as my old one had cracked connectors- the "green wire" purchased from out host- Pelican Parts- had to pull the distributor, after PITA removal of Turbo plumbing... had #1 at TDC w/ rotor also at #1 mark on the distributor lip, also scribed the position of the washer under the timing adjustment nut on the distributor- put in the new "green" cable, cleaned the distributor a bit, carefully re-installed the distributor to my marks so that the timing would be close, clipped on the new cap w/ new rotor/wires, and then struggled for the next hour to get the Turbo plumbing back on- ended up putting a jack under the engine, removing the rear engine motor mount cross bar, then easily replacing the Turbo stuff, reinstalling the motor mount, etc.....
No start..... much yelling, screaming, knashing of teeth...... a friend said-"you probably are a tooth off on the drive gear"- I said no, here are all my marks- it's right on the money- he said "humor me, move the distributor"- I said a case of beer to you if I made such an amateur mistake- I will jump for joy- moved it to the extreme end of travel, and it cranked and ran- roughly.....
so, with a REAL PITA, you can raise the distributor/cap enough underneath the turbo pipes to reset the teeth- got it to run, set the timing, at 4000rpm per manual- STILL has a misfire- somewhere:confused:........
Talked to Lee Rice (riceturbos@sbcglobal.net), author of several articles in the Pelican library of tech stuff, initially about my CIS FD?/WUR? problems a month/6weeks ago, and now about this misfire.....
IN A THOUSAND YEARS, I WOULD NOT HAVE FIGURED OUT THIS MISFIRE!! the only distributor repair cable that Pelican sells- "the green wire" is for Distributors that run CCW- 78s and later...... my Turbo and the earlier cars run CW..... ( called my salesguy at Pelican yesterday, he was not aware of this problem- he is alerting the sales department- wonder how many they have sold for older cars...???- they list this as the proper part for my '77 930 once you plug in what car, year, engine you have ).....
I have to reverse the polarity of the pickup lead- to change the pickup point on the 6 point reluctor in the distributor from the leading edge to the trailing edge of that reluctor- depending on direction of rotation!- can be done at the CD unit, but probably best to do it at the female connector after the "green wire"....... as it is, the #1 plug isn't firing until about half way between #1 and #6 wires... the engine will never run smoothly smooth without this... I couldn't set the idle rpm per spec, so I set the rpm at 4000 w/ the vacuum line disconnected- because of the pickup for CCW, I guess it's negating the vacuum part of the advance as well..... as we all know, Pelican sells 1000s of parts for numerous makes- they are looking into the proper cable for the early cars....
as far as the low system pressure from the FD-WUR, Dale at Jaytan is sending me some shims (thank you PaulPorsche) to increase the system pressure up into the spec 6.0-6.7bar range....
NOW for my latest issue- have TIMING CHAIN slap - rt side of engine--- wasn't sure I was hearing it correctly in the garage, backed it out 20 feet- YEP!!!- put it back in the garage, shut it down...... haven't had time to start tearing into the timing chain boxes to see what's going on- it does have the 930 tensioners in it- but put in there 22-23 years ago... time/age?...... am still paying the price it seems for not running this engine much for the last 12 years.....:(
will update again when I know more.... CALL ME IF YOU EVER HAVE ANY BRIGHT IDEAS OF TAKING OUR PRIDE AND JOY APART FOR COSMETIC PAINT, THEN HAVE KIDS, REMODEL TWICE, MOVE, CHANGE JOBS, ETC,ETC. BECAUSE YOU LIKE DOING IT YOURSELF.... bite the bullet, take it to a great paint shop, let the guys that do it every day handle the job.....
will post pix- the car looks great- new dash, headliner, rubber, re-dyed white leather interior etc- BUT refer to the above paragraph for sane advice....
Tim
Alpine, Az;)
Paulporsche 09-29-2009 02:26 PM
Whew! Stay w/ it! You're getting there!
