dcarlson's Avatar
fuses in engine compartment
anyone know what the 3 small fuses on drivers side of engine compartment are for? they are under the plastic flap held with two butterfly screws on the side wall near the coil. '86 911 cab.
'86 944
'86 911
07 cayman
Old 02-21-2013, 01:08 PM
scarceller's Avatar
- Rear Defroster
- Rear Wiper
- Heat Control Relay
And if you have a Cab then the rear window wiper and heater are not used. You should only need the fuse for the heat controller
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 02-21-2013, 01:17 PM
dcarlson's Avatar
hey thanks! I see all 3 fuses in place - there was some detail on the inside of the cover I had not first seen- as you say, some are not not in use for the cab - funny they are in there but some kind of German logic must have prevailed..........
'86 944
'86 911
07 cayman
Old 02-21-2013, 01:25 PM
scarceller's Avatar
Not only are the fuses there but so is the relay for the rear window heat element.
Sal
1964 356SC (SOLD)
Old 02-21-2013, 01:31 PM
