				14 pin connector
			1977 Carrera 3.0(ROW), so probably same as 78SC. Anybody have a pin wire chart they could scan and send me, please.
	Mill Beatty Coordinator for the 911 Carrera 3.0 North American registry site>  |
			1979 SC - may be the same or close
			1 Yellow Starter signal 2 Green Oil Pressure switch? 3 Green/ Black Oil Temp 4 Green/ Red Oil Pressure sender 5 Green/ Yellow 6 Grey/ Red 7 Grey/ Blue 8 Brown/ White 9 Green/ White 10 Red/ White 11 Blue Charge indicator light 12 Black/ Purple Tach signal 13 Yellow/ Black 14 Red Power
	Rex 1975 911s and 2012 Range Rover Sport HSE 1995 BMW R1100RS, 1948 Harley FL  |
			The 77 carrera harness is closer to the 77S than SC
	Bruce  |
			 bigsid
			Copied from Marc's 3.2 conversion site
	This is the 14 Pin Male in the '77 engine bay. The pin assignments are as follows: 1. yellow - starter Kl.50 2. brown/white - To a harness below the shift lever 3. green/black - Oil temperature Instrument 4. green/red - Oil pressure Instrument 5. green/yellow - from ignition.( Kl.15 ) to backup light switch 6. gray - backup light switch to lights 7. blue/yellow - To fuse on panel in engine bay 8. green - To a harness on the trunk floor 9. green/white - Oil pressure idiot light 10. red/white - Thermovalve 11. blue - alternator control light Kl.61 ( or D+ ) 12. free 13. black/yellow - power source for the fresh air blower 14. red / source from alternator Kl.30 or B+ In my case, I removed the #2 pin and #8 pin from the female connector. I did not cut the pins off so that if they are needed in the future, they could be re-inserted.  |
			Thank's all, should help!
