LinkBack Thread Tools Rating: Thread Rating: 3 votes, 5.00 average.
Lightbulb Budget Targa Top - Super lite
I just finished up a really cool project, I will post more of a write up here later, I really don't have a lot of time now but here are the basics;
A.) Materials
1 Sheet of 3/16", 32" x 46" Lexan
16 1/4" Screw post
4 3/4" Screw post
4 3/8" Screw post
2 2" Screw post
One original Targa top folding frame and seals
Clamps
Drill
Screwdriver
B.) Prep
Remove old top
Drill out Rivets
Clean glue off everything
C.) Template
Create a template from cardboard leave about 1/2"
Once you get it right cut the template out from the lexan using a jig saw.
D.) Drill and attach
I will edit this later as I had to do this many times and lots of trial and error. You have clamp it in place and then work from the center to the outer edges making adjustments.
E.) More pictures later
This is my second top, I have a folding one as well, I initially intended to cover it with vinyl but the clear has that "Ace" feel to it and really works well. I used the original seals as well and have driven it at speed in the rain and am proud to report that it seals completely.
Old 08-11-2009, 07:44 PM
Make My Day
wowzer911's Avatar
I'd like to see more pictures.
I bet tinted lexan would be cool too.
I have a Saratoga top that I like alot.
74 911S Targa ROW
Building Designer/Business Owner
Old 08-11-2009, 08:17 PM
Deplorable Member
Porsche-O-Phile's Avatar
That is kinda' cool - I definitely give you credit for innovating. Just a couple of quick questions:
Doesn't curved glass form uh... a lens? Magnifying glass effect potentially? I remember seeing a thread on a motorcycle forum where someone custom-made a windscreen (also curved lexan) and it did this, melting the guy's instrument cluster.
Lexan scratches up pretty easily - what to do about that?
Does lexan do anything to shield against UV? I wonder about that. Then again, I suppose if the car is parked inside a lot maybe it doesn't matter.
Very cool though. Interesting thought - almost like the "new" targas look.
Maybe you could rig up a snap-on type of liner that goes on the inside to help with UV/prying eyes. A boat canvas place could probably do that.
I think the fasteners should be not visible. Maybe countersink them/flush fill with epoxy and just do an opaque/black band around the perimeter of the top about 2"-3" wide? Plus this would give a place to grab onto without leaving grubby hand prints on the lexan.
Damn cool idea though.
'74 911 Targa 2.7 (in storage, hoping to finish "someday"), 2001 Mercedes SLK 320 (with a few AMG fun bits), '85 BMW K100, a few surfboards
Black Cars Matter
Old 08-11-2009, 08:19 PM
Thanks for sharing this project. It looks great! I'm looking forward to reading more about it.
Cheers, John
1982 SC Targa
1970 T 2.4E/915(project)
Old 08-11-2009, 08:22 PM
I was told by the supplier that tint has a different expansion rate then lexan so the tint will split after exposure.
Jeff,
I really haven't noticed a magnification effect but I will keep an eye on it, I hadn't considered that, thanks for the heads up!
"I think the fasteners should be not visible. Maybe countersink them/flush fill with epoxy and just do an opaque/black band around the perimeter of the top about 2"-3" wide? Plus this would give a place to grab onto without leaving grubby hand prints on the lexan."
I originally planned on covering the whole thing, But I like the idea of using a band around the edge to cover the screws and to keep the bugger prints off.
I don't think there is enough material to properly countersink the screws, it would take some finesse, I used 3/16th so I could cold-form it, the thicker piece is 1/4" and I don't think I could have bent it. This top weighs less than the stock top.
Thanks for the comments, the longest part in the whole process was getting the template perfect.
Shane
Old 08-11-2009, 08:34 PM
Banned
WOW, very impressive !!! About a month ago I fabricated a shrouding to perfectly fit an aftermarket intercooler to my 930 tail, so I can relate to the "trial and error" part of your project . . . VERY nice work !!!
R
Old 08-11-2009, 08:35 PM
Make My Day
wowzer911's Avatar
I meant tinted lexan, (which you can buy) not window film tinting.
That and black fasteners would be sweet.
74 911S Targa ROW
Old 08-11-2009, 08:43 PM
Wowzer.... can you point me to a source for the tinted lexan? I havnt been able to find one.
Curved glass worked out for these guys...
Old 08-11-2009, 08:50 PM
Deplorable Member
True - I know there are other curved "bubble" forms so it probably depends a lot on the specifics and radius of curvature, etc. I just remember seeing the "after" pictures of that one guy who made the curved windscreen and - MAN! Just one of those "unintended consequences" things.
I suspect given how shallow the curve is on a targa roof it's probably a non-issue, but just something to think about.
This is a super cool idea that's got a lot of potential for those of us wanting a nice custom touch...
Black Cars Matter
Old 08-11-2009, 08:58 PM
Deplorable Member
Some kind of metal strip around the outside edge would make a nice accent too - just thinking out loud. This is a captivating idea and I keep coming back to this thread to look at it...
Black Cars Matter
Old 08-11-2009, 08:59 PM
Cool
P-O-P, thanks I'll keep an eye on it....
P.S. Lexan = 63$
Hardware = 30$
Look on Shane's face when he returns to his smoldering car being hosed down by the Fire Department = Priceless
Whats in your wallet? (can I say that?...legally?)
Old 08-11-2009, 09:02 PM
Arrow More Pictures
Stock folding top = 22 lbs.
This Top = 17 lbs.
Difference = 5 lbs or 25% weight savings.
Old 08-11-2009, 09:46 PM
Do you have inserts to block the sun?
Bryan O.
77 930
08 Boxster
14 535i M Sport
Old 08-11-2009, 09:56 PM
The Puff.
Mr.Puff's Avatar
Darn sexy . I like it a lot!
'70 CT1B
'11 GTS 300 Super
Old 08-11-2009, 10:38 PM
MichiganMat's Avatar
Send a message via AIM to MichiganMat
That looks pretty awesome actually, nice job.
Id love to see some pics out in the sunlight
'75 911S 3.0L
'75 914 in progress
'67 912R-STi
'99 LR Disco 2
Old 08-11-2009, 10:43 PM
tb912's Avatar
Amazing. I'd pay you to make me one if I had a targa.
1968 Light Ivory 912
1974 BMW 2002
Old 08-12-2009, 12:31 AM
T77911S's Avatar
very nice. i have always wanted some sort of hard top for my car. more pics please.
something else i have always wanted was something made out of a cloth with maybe just some rods on the sides that was very easy and quick to put up to keep the sun out while the top is off and i am not in the car. i expect something by monday morning.
86 930 42kmiles [__] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD
88 BMW 325is 200K+ SOLD
05 BMW 330CI 130K:: [__] RUNNING: [__] NOT RUNNING:
08 VOLVO V70 190K:: [__] RUNNING: [__] NOT RUNNING:
90 B2200[__] RUNNING:[] NOT RUNNING:__2000 MER E320 WAGON [] WRECKED:[]RUNNING:
Old 08-12-2009, 03:01 AM
12 years and 17k posts...
azasadny's Avatar
Excellent idea! I'd love to have one of those!!
Art Zasadny
2010 MazdaSpeed3 (daily driver)
www.ford.com
Old 08-12-2009, 03:32 AM
Ray_G's Avatar
Thanks for sharing this great idea. I have a second targa top that has a lot of corrosion in the center panels. The frame is good. I know what I am going to do with it now.
76 911S Targa
An ex F1 driver, and Porsche fanatic (my stepfather) once told me that if you listen very carefully on a quiet night you can actually HEAR Porsches rusting in the garage!
Old 08-12-2009, 03:40 AM
Make My Day
wowzer911's Avatar
Here's one source for the Lexan: http://www.mcmaster.com/#polycarbonate-sheets/=35ltid
There's a few options, translucent bronze, gray, white. Also Opaque black, Clear w/ mirror finish. Could make for some interesting looking Targa tops.
3/16x4x4 sheet transl. bronze is $106, not too badly priced...
74 911S Targa ROW
Old 08-12-2009, 03:56 AM
