PatrickM's Avatar
Parking lamps not working
on the passenger side. The driver's side works fine. Any ideas? Thanks!!
Old 08-13-2009, 10:23 AM
check the bulb..swap with the good side
check to see if you have power to the socket
If no power trace the wire back to the connector
If you have power then check the ground connection
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 08-13-2009, 11:35 AM
