Early '73 fuel tank installation
In the process of installing the fuel tank after rust treatment and flushing.
This is the only time the tank has been removed and the gasket material was for
the most part, missing. So---it was impossible to see where the gasket seals and
if it should be applied to the body sheet metal or the tank before it is dropped into
the hole.
Anyone with this experience should bless me with their knowledge and I will be
forever grateful!
Well----maybe for a day or so.
Is the stock gasket the same for top or bottom? How thick is it supposed to be?
Thanks, anyone!!
Grampy
Old 08-14-2009, 02:44 PM
Friend of Warren
Apply to sheet metal. It is high density black foam. Save some money and just go to the local hardware store and buy a roll of 1/2" thick high density black door foam insulation. Should run you around $4.00.
Kurt V
Old 08-14-2009, 02:49 PM
along the edge of the tank, not the body.
John
997 C2S 2005 "Slate grey"(special order 1965color)
911 SC 1978 Silver/black 34.000 miles from new!
911 2.2 S 1971 Albert Blue/Black and 911 2.2 T 1971 Tangerine/Blood Orange/Black
Sold: 911 2.4 S 1973 Viper Green/Kelly Green; 993 C4S 1996 Black/black; 993 C4 1994 Black/Black; 996 C4 2000 Black/Black; 996 Turbo 2003 Silver/Black
Old 08-14-2009, 03:51 PM
