CharlieB's Avatar
Horn Relocation Kit
Getting ready to update my 80SC from trombone to carrera oil cooler without fan for now. Got all parts except the pictured "horn relocation kit" which is NLA. Right inner fender support is PN 911-504-080-00 or 911-504-080-00GRV. Is there a difference in the stock part itself or is the "kit" something special? Can I just use a regular Carrera fender support, fab a horn bracket and move it forward? Anyone holding on to a "kit" they care to part with or a stock fender support if that can be used with a fabbed horn bracket and relocated?
Old 08-14-2009, 06:11 AM
Friend of Warren
Haven't had my horns off in a while, but as I recall the bracket is nothing special that you couldn't fab up from some strap steel.
Kurt V
Old 08-14-2009, 06:24 AM
scotricker's Avatar
Hi Charlie, I don't have an answer for your question today... but I'm planning the same upgrade for my 78. So please post progress reports as you go along with this project! Thanks!
Scot
78 911SC coupe, sold,, 2019 Macan S
"my friends all drive Porsches, I must make amends.."
Old 08-14-2009, 06:55 AM
mca mca is offline
mca's Avatar
I did this a couple of years ago (elephant cooler) and didn't have to move the horns on my 82SC. I was able to push each horn forward at its base - each horn is on a smaller, more flexible bracket that attaches to the larger bracket (if I recall correctly).
However, I believe that if you ever add the fan you will have to relocate the horns.
Try to test fit first.
It is nice to get a helper with this job. Makes it easier to align and manipulate the fittings.
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 08-14-2009, 11:14 AM
