It will get done! --Puff |
A Pelicanite nearby may be able to help? SmileWavy |
It's back in! Never mind the dangerous and precarious positions that resulted in victory ;).
--Puff |
Good, glad nobody got hurt sounds like it was harrowing I hope you took notes and lessons learned for future drops, I did the first time. My biggest oops the first time was not hooking up the engine ground left me scratching my head for hours. The last time I thought I had the clutch fork engaged in the throwout bearing good thing I tried to hook up the clutch first and found it very loose didn't lose much time as a result.
Good going, Mr Puff. My factory manual says to take the engine and transmission out as a unit. Try that next time as I'm sure it has to be a lot easier, and in the end, quicker. You might check out the device that our sponsor sells for removing the engine on a floor jack. I bought one, and it IS easier that what I've done for the past 30 years.
Good Luck! |
| All times are GMT -8. The time now is 12:31 PM. |
