Anyone tried the repro early 911 turn signal housings?
Comments good or bad? Quality?
Thanks!
Old 08-03-2009, 09:18 AM
Zeke's Avatar
I have them and they are junk if you're looking for show car quality. Otherwise, they will pass. On one of mine the wiring was not completed inside. I had to open it up from the back and attach the wires. It did not work out of the box. Just recently a lamp fell out of the housing inside the lens. I had to make a shim to get it to stay. I used to do this on old housings.
Old 08-03-2009, 11:43 AM
O.K. Milt so what do you use for shims for your turn signal bulbs?
Old 08-16-2009, 09:46 AM
flat tooth pick.
206 637 4071
Old 08-16-2009, 10:22 AM
