84-85 v 86-89 torsion bar & sway rates change
I found this neat formula for calculating the difference between torsion bar sizes.
It is the larger bar to the fourth power / the smaller bar size to the fourth.
Porsche changed the rear torsion bar from 24mm to 25mm and the sway bar sizes from 21/18 to 22/21 in 1986.
This had the following effect.
The rear torsion bar change from 24 to 25 is 17.7% stiffer.
The rear sway bar change from 18 to 21 is 85% stiffer.
The front sway bar change from 21 to 22 is 20% stiffer.
Thus, Porsche stiffened up the rear "spring rates" of the 86 and newer significantly more than the front.
I could be wrong and because of other factors this might not translate to "wheel rates" in the same relative amount.
Old 08-18-2009, 09:44 AM
A popular up grade is to 22/28mm torsion bars. If starting with 18.8 /25mm torsion bars this is:
18.8 to 22mm is 87% stiffer.
25 to 29mm is 81% stiffer.
24 to 29mm is 113% stiffer. (pre 86 rear)
Caution using this by itself as the sway bar may be almost half the effective wheel spring rate.
Old 08-18-2009, 09:54 AM
