Send a message via AIM to NONO5.0
One LAST question about the the Shift Coupler Bushings
Sorry for starting a new thread, but it is kinda a different issue I got the new bushings in just fine using a vise and some sockets. The install wasn't that bad, BUT now that its all together, it is VERY snug. Should it be really snug? I can move it up and down with my hand but not really easily. Before, it would just wobble in place (even before I lost the bushing) I'm guessin that its normal b/c of the new tight bushings, but just wana be sure.
Thanks again everyone!
Old 08-20-2009, 05:56 PM
Oh Haha's Avatar
Sounds like it's just right. Good job!!!
Pacific Blue
Wayne
Old 08-20-2009, 06:37 PM
winter
Winter's Avatar
Yup, you nailed the job!
Be sure to follow the advice here on adjusting the shifter when you bolt everything back together again. I think you'll find that the new bushings will really make a difference.
Tom '75 targa
Old 08-20-2009, 06:40 PM
winter
Winter's Avatar
thought I'd make it even easier for you (as described in the Pelican tech articles):
a) Take off the cover between the rear seats which exposes the shift coupler. Pull up the shifter boot, particularly so you can see the lower part of the shifter lever where it bends from "angled back" to more vertical.
b) Loosen the retaining bolt which pinches the shift rod on to the spline on the shift coupler. Let it be very loose.
c) WITH THE TRANSMISSION IN NEUTRAL, rotate the shift coupler clockwise when viewed towards the front of the car. You should be able to feel the coupler rub against the various shift stops as you rotate it back and forth. Rotate it to the furthest clockwise position, as seen when you are facing forward. Don’t pretend you are Tarzan and turn it with huge force....lightly is all that is necessary..
d) Keep your hand on it and hold it there. Don’t let it wiggle, if it does, turn it back to the furthest clockwise position.
e) Move the shift lever so that the more vertical part of the lever is vertical (ie 90 degrees to the level...sticking straight up so to speak). Move it so that it lightly touches the side of the shifter housing which is on the 1st/2nd gear side.....closest to the driver. Again, gently.
f) They should now be properly aligned.....lever closest to the driver with bottom part vertical, coupler clockwise in the neutral plane.
g) Carefully tighten the pinch bolt. Make sure it is quite tight.
h) Check things out. You must be able to engage reverse clash free (give the gear a little bit of time to stop after you stomp on the clutch), shifting should get to all the gears easily when driving.....things don’t work as smoothly when stopped and lastly, there must be a little bit of rotational play when 5th gear is selected. This is checked by shifting into 5th, and feeling whether you can wiggle the shift coupler with your hand. It should just click back and forth slightly...not much, but clearly discernable play.
i) Assuming all is well, put all the covers back. If it is not well....my fervent suggestion is that you START OVER at b. ....I have never had any luck fiddling with the linkage.
Tom '75 targa
Old 08-20-2009, 06:43 PM
Thanks a lot guys!
