krd krd is offline
krd's Avatar
tachometer and druck press question (with pic).
If i'm running at about 2500 RPM's, what should my druck press read? Is there a rule of thumb?
1988 porsche 911 "CE" cabriolet
Old 08-23-2009, 05:44 PM
Oh Haha's Avatar
ROT is 10psi per 1000 RPM's
Yours seem to be just fine.
Pacific Blue
Wayne
Old 08-23-2009, 05:50 PM
Monkey Butt Forespin
84_Carrera's Avatar
And to clarify, you're looking at BAR, not PSI. So, (for example), at "3" on the gauge, you're at 3 BAR, or nearly 45 PSI.
Fred Hurder Jr
For Tech Questions:
'84 911 Carrera Cabriolet (US)
Weltmeister Chip, Fabspeed Euro Pre-Muffler, M&K 1-in / 1-out Muffler
22 ERP /29 Sander Hollow T-Bars, Bilstein HD Struts / Sport Shocks
ERP Poly-Bronze Bearings (A-Arms & Spring Plates), Stock Swaybars
Turbo Tie Rods, '92 C2 5-Spoke wheels w/ 1" adapters, Drilled Zimmermans
Yes, I drive mine as much as possible. If it's >32° & sunny, I've got the top down.
Old 08-23-2009, 06:08 PM
Friend of Warren
Looks fine to me.
Kurt V
Old 08-23-2009, 06:21 PM
Dixie Region R Gruppe
w21055's Avatar
Looks fine, but should dip a little once it warms up so if it does that do not freak out.
Instagram @phillipkj4
1980 911 SC Backdated Viper Green
1992 Ferrari 348TB
Old 08-23-2009, 06:23 PM
That looks exactly the same as mine.And I just did a three thousand mile road trip.You have no worries
Kevin
Old 08-24-2009, 12:48 AM
a.k.a. G-man
Geronimo '74's Avatar
I agree, looks fine
Old 08-24-2009, 12:54 AM
83 911 Production Cab #10
JJ 911SC's Avatar
Porsche Crest From an "1983 Owner's Manual"
krd
Verbatum from the guide: "Oil pressure in the engine is show in bar. With the engine at operating temperature (194F/90C) and the engine speed of 5000 rpm (revolution per minute), the oil pressure should be about 4,0 bar. At this operating stage, the needle in the oil temperature gauge should be at the upper edge of the white-rimmed field. A drop in oil pressure at high temperature is normal. At idle speed, with the engine oil hot, it is normal for the red control light to light up - this does not indicated any loss of engine performance."
I never experience the red light coming on.
Mine used to be all over the place at idling and way past 5 with any revs. A 30 minute cleaning job fix it up (connector and the post at the sending unit). She is now steady with the following results:
1 at 850 rpm
2 at 1550 rpm
3 at 2000 rpm
4 at 3000 rpm
4.5 at 4000 rpm
and barely 5 at 5000 rpm.
J.J.
Old 08-24-2009, 01:58 AM
Originally Posted by JJ 911SC View Post
krd
1 at 850 rpm
2 at 1550 rpm
3 at 2000 rpm
4 at 3000 rpm
4.5 at 4000 rpm
J.J
My gauge is exhibiting the same symptoms...since I'll be under the next weekend putting in Swepco do you have any photos/info to fix the connector and sending unit to avoid this problem?
Old 08-24-2009, 07:53 AM
JJ 911SC's Avatar
Picture fot Testing the Gauges (Oil Pressure & Temperature)
Hi KSUGreggy
It's rather easy to test and clean. A bit harder if you got an A.C. unit installed. Even with my A.C. fitted the bracket kind of stop the connector. I had to pry it sideway, luckily it did not break. From other thread sometime the cable is cooked to a crisp and break.
In the first picture you can see the sending unit with the connect on top. To the lower left of it is another connector for the temperature. with the car nor running, unplug both wire (Pressure & Temperature). Once unplug, turn the ignition on (not staring) and both gauges should deflect all the way up. If you ground the leads, they should deflect all the way down.
I clean the post and the inside of the connector put it back on the post and it work like a charm.
Cheer
J.J.
Old 08-24-2009, 08:43 AM
JJ 911SC's Avatar
Cool Second Picture
Pictures with the connectors removed and cleaned. On my car, when I put the Pressure connector back it seem loose but worked properly.
Old 08-24-2009, 08:48 AM
Less brakes, more gas!
euro911sc's Avatar
FYI I have the restricted cam tower adapters in and my Druck press is pinned just off idle. So...
-michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 08-24-2009, 10:59 AM
gulkster's Avatar
Temp shows you at ~90C, which is where mine resides 95% of the time (once warmed up) so I wouldn't expect the pressure/rpm ratio to change much from where you are. Might drop if you idle in traffic for a long time and temps creep up, but as everyone has already pointed out, the pressure looks in the "normal" range.
T-Shirt wearing, sticker toting, SCWDP registered member
Why when you misplace something is it always found the last place you look? Because you stop looking after you've found it
'83 911sc ROW Targa
'84 BMW 320i (what did I get myself into?!)
Old 08-24-2009, 11:16 AM
Senior Advisor
James Brown's Avatar
NOTE: druck=pressure in German so if your saying "druck pressure" your saying pressure pressure
and it's in bars not psi......you have been schooled
08 Cayenne Turbo
Old 08-24-2009, 11:49 PM
dshepp806's Avatar
I've seen few that exhibit linear behavior..I'm looking to check my connections at meter's rear (as I've changed my sensor out)...it's time to have a look behind the gauge (and the gauge, itself).
Best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 08-25-2009, 04:53 PM
