speedo stops when dash lights on...
OK, the speedometer in my 1988 930 stops working when the dash lights come on; really. The needle drops to "0" as soon as the guage lights up. Anyone have any ideas??
Thanks, RD |
Sounds like a weak common ground connection somewhere behind the intruments
RRD,
I got your pm, I have a similar problem...works without lights on but doesnt give accurate reading. what are the voltage ranges for the signal wires? it would be easy to test if I am getting a signal. JF, I can rewire a ground easy enough, ill try it out |
Yes,...ground checks first.
Best, Doyle |
| All times are GMT -8. The time now is 02:49 PM. |
