-   -   3.2 DME tester - my newest project (http://forums.pelicanparts.com/porsche-911-technical-forum/492967-3-2-dme-tester-my-newest-project.html)
ischmitz 08-19-2009 10:42 PM
I finally got my newest project to work satisfactory - a 3.2 DME test station. I built it into an old discarded power supply box I got out of the junk pile where I work.
http://forums.pelicanparts.com/uploa...1250746402.jpg
The tester simulates all inputs to the DME and is able to test all outputs. Here are some specifications. It can simulate the following inputs:
- reference and speed sensor 0 - 8000 RPM
- cylinder head temperature (CHT) sensor full range
- O2 sensor signal rich, stoichiometric, rich
- idle switch
- wide open throttle (WOT) switch
- intake air temperature (IAT) sensor full range
- air flow meter signal (AFM) full range
- cranking signal
The monitored outputs are:
- injector stage into an inductive load simulating the injectors
- Ignition into an ignition coil and spark plug
- RPM signal
- DME relay signal into a relay and indicator
- Idle control valve signal into an ICV
All important outputs and the reference signal are available on BNC connectors on the front panel for easy access with an oscilloscope. Let the testing begin. With this tester I can visualize and display the idle feedback behavior, spark advance in relation to the RPM and AFM signal, cold start enrichment, the O2 sensor-related mixture control, deceleration fuel cutoff, WOT spark advance and many more things.
Ingo
88-diamondblue 08-19-2009 11:17 PM
That is just awesome. :cool:
I'll be the first in line to send mine if you need another one to test since I am having a problem with my car running rich and haven't found anything that tests bad yet.
saint914 08-19-2009 11:54 PM
Great
Hi, that's great, think of the fun you can have simulating different temp and load paramaters.....
gregwils 08-20-2009 06:26 AM
I am envious. I wish my brain was capable of producing this type of stuff, but I don't believe I have the aptitude and I definitely don't possess the knowledge. I am sure you enjoy sharing this skill set since most of us appreciate it, but it's also great that you are willing to share - like so many others. Thanks.
dw1 08-20-2009 09:16 AM
Oh wow!!
Man, you just saved me a buttload of work, as I was starting to engineer a system like this!
(Well, my enclosure was a different shape, but it was also "recycled" from some obsolete equipment at work.)
If you would be so kind, can you e-mail me a schematic?
Thanks much.
ischmitz 08-20-2009 09:56 AM
Sorry dw1 but I don't have a dedicated schematics of any sort. I simply whipped up a couple of waveform generators based on the ICL8038 for RPM and O2 signals and then used two 74ALS169 synchronous counters as a frequency divider to get the reference pulse derived from the engine speed pulse. I used the data sheets and some generic PCB board and soldered little wires to it. It ain't looking pretty but it works. I didn't create any documentation.
I can post a picture of the inside of the box when I get home tonight but it'll take away from the beaty of this. It looks MESSY... ;)
Ingo
ianc 08-20-2009 10:20 AM
That is about the coolest thing I think I have ever seen. Well, almost...
So can we all send you our DME's now for test? ;)
ianc
KTL 08-20-2009 10:29 AM
Ingo
You make it sound like, "Meh, I just cut a few pieces of wood and screwed it together. It's a bit crude, but it works....."
Guys like Ingo that understand all that stuff are a huge benefit to those of us who don't have a clue how these things work!!! Hey, somebody's gotta know how all the electrons make magic
GH85Carrera 08-20-2009 11:31 AM
If I go to Radio Shack and ask them for a couple of waveform generators based on the ICL8038 for RPM and O2 signals and two 74ALS169 synchronous counters as a frequency divider how puzzled do you think the employees will be?
charlesbahn 08-20-2009 11:31 AM
Very cool. Another option is a break out box. With the one shown as posted below I can monitor all functions of the DME in real time in the car and while driving. Watch EBAY/craigslist for the box and cable, they come up from time to time for not much $, but you have to know what you are looking for.
http://forums.pelicanparts.com/porsche-911-technical-forum/33877-dme-breakout-box-where-can-i-get-one.html?highlight=breakout+otc
Joe V 08-20-2009 11:38 AM
Cruise control tester?
Ingo,
Do you see a cruise control brain tester in your future? ? With all the "accelerates, but won't hold speed" issues, you'd make a mint in diagnosis, and possibly repair.
911st 08-20-2009 11:49 AM
Cool.
Wish someone would come up with how to add a TPS and convert it to a MAP system like Proto. dose.
Wavey 08-20-2009 02:28 PM
Wow, nice work Ingo! If Loren was still here, he'd be having a stroke right about now.
KTL 08-20-2009 02:40 PM
I was thinking the same thing when typing my response....... :D
nesslar 08-20-2009 03:00 PM
Wow. Nice work, to say the least! It's the DME Frankentester! :cool:
rick-l 08-20-2009 03:56 PM
How did you simulate the two variable reluctance sensors?
ischmitz 08-20-2009 10:28 PM
An ICL8038 with 0-20 kHz variable square wave output coupled to the inputs via small capacitors to remove the DC component for the speed sensor.
Then two 74ALS169 cascaded counters to get a reference pulse every 129 pulses. I had to play a little bit with some RC network to get a nice zero-crossing. It turns out the 3.2 DME isn't very picky for both signals.
When it comes to the 60-2 signal for the later DME it is a whole different ballgame. That DME cares about the polarity of the zero-crossing for the missing tooth signal.
Ingo
rick-l 08-21-2009 12:07 PM
Since this thread has all the electronics guys attention
Is this the way the DME ignition controller charges up the coil (the output of that differential pair and darlington)?
In THIS THREAD he says he measures 4.5 volts across the coil. Is this what he sees? 32 watts in the coil and 70 watts in the darlington with the key on engine off seems kind of high.
The arbitrary behavioral voltage source applies either 13.5 volts or the error of the current compared to 8 amps. Of course in the DME it is on the low side.
http://forums.pelicanparts.com/uploa...1250881337.jpg
http://forums.pelicanparts.com/uploa...1250881357.jpg
88911coupe 08-21-2009 05:46 PM
I can't even begin to comprehend what you've accomplished...I just wish I knew how to do that sort of thing.
spencejm 08-21-2009 07:06 PM
I think a more "realistic" (anyone get the pun?) question would be to ask how confused they would be if you asked for a simple resistor!
ischmitz 08-21-2009 10:00 PM
Rick, I assume what you plotted is a spice simulation, right.
The 3.2 ignition works just like a simple Kettering ignition. The only difference is that the points are replaced by the darlington transistor in the DME. It switches GND to the coil for the dwell time (charging it) and then turns off. There is a current feedback to limit the charge current through the coil.
Once the darlington turns off the magnetic field collapses and that is what produces the high-voltage spike on the secondary.
You shoud not measure any voltage across the coil with the engine not running since there is no current flowing through it. But both sides of the primary should measure 12 volts towards GND.
James Brown 08-22-2009 01:47 AM
closest thing I have to "realistic" is my "zenith".......cool stuff, keep it up
rick-l 08-22-2009 09:24 AM
I was wondering what the stuff in yellow did. To me, after some arduous calculations, I figure it limits the current to about 8 amps.
When you turn the ignition on is there a constant 8 amps going through the coil? (Before the engine runs)
EDIT: let me rephrase that. When you turn on the ignition does the DME wait for speed sensor inputs to charge the coil or is it always on?
http://forums.pelicanparts.com/uploa...1250958074.jpg
ischmitz 08-22-2009 11:19 AM
The coil is only charged for the dwell time when the DME receives a signal on the speed sensor input. Else the Darlington is off the and the coil isn't charged. So with the ignition ON but no cranking the coil isn't charged.
And yes, the yellow box is a current sense-driven current limiter. The 0.05 Ohm resistor measures the current.
rick-l 08-22-2009 12:39 PM
So the guy in the other thread you can conclude his DME is Tango Uniform if he sees 4.5 volts across the coil primary. :(
The other thing I was trying to figure out is that network down and to the right of the yellow box. It is obviously a network to keep the Darlington from going into deep saturation but I haven't seen anything like that before.
When you change T504 what parameter do you look at to choose the Select In Test (SIT) resistor R517? At least I think Abgleichwiderstand translats to SIT.
I can see R526 and R508 (both have A on them) would be selected to adjust the current.
Wavey 08-22-2009 06:28 PM
You guys are just making all this up, right?
ChrisBennet 08-22-2009 07:22 PM
Years back a started/tried to make something similar only using a PIC processor to make the timing and reference signal. Hat's off to you!
-Chris
ischmitz 08-23-2009 11:26 PM
I have seen PIC-based solutions from the Megasquirt crowd before. Quite nice but I simply don't have the patience to learn programming for these little buggers. See here for a superb example: http://jbperf.com/JimStim/index.html that can actually be configured without programming skills.
It makes my signal generator look like a stone age tool in comparison. ;)
I also used the sound card for a 60-2 wheel before but then I always needed the PC next to the tester. Cumbersome, but it worked. See here: http://www.megamanual.com/router/crankwheelpulser.htm
Joe Bob 08-24-2009 01:42 AM
Smoke and mirrors.....he just does miracles.....
McLovin 09-28-2009 10:43 AM
LOL.
That creation is damn sweet.
The function is unbelievable, but I also like the retro/mad scientist look of the contraption!
