correct bulb type for early turn signal
Hi All,
Just received some reproduction early (pre-'73) turn signal housings. These have sockets for two bulbs. A dual filament bulb up front, and a single filament miniature bayonet bulb on the side. Could someone please tell me the correct bulbs i need? Thanks, Adam |
I assume you're talking about the front, not the rear?
For front, you need: (1) 2cp = type 1895 (or 3893) (1) 21/5W 32cp = type 1034 (or 7528) - this is the dual-filament bulb. The 3893 and 7528 bulbs can be bought from our host. |
For the rear, you need the same two bulbs as the front, PLUS:
(2) 21W 32cp = type 1073 (or 7506) The 7506 can be bought from our host. |
thanks for the replies... you were right that I was after the fronts.
Just getting everything ready for my backdate, as are you I see... One question, i currently only have one bulb per side in my front turn signals. If I add an extra bulb, will this change the total resistance of the circuit, making the lights blink at a different rate? |
I too need the smaller size bulbs and couldnt find where to get them. thanks for the info Paul |
| All times are GMT -8. The time now is 05:43 AM. |
