Quick Learner
My transmission... what is it?
Hey all!
Had a fellow Pelican visit today and help figure out my project. He said to post the numbers off the bottom of my transmission when I got it apart, and I would find out what it is, and if its any good... ![]() So, here is what I have: 911 0 7101747 There may be another "1" after the first 0, but it looks like someone hit a rock or something, so couldn't be sure. Thanks!!! |
probably should look like this..
911/01 Then the next couple numbers should tell you 4 speed/5speed, T, E, or S should be a 70/71 901 trans with the designation 911 for the bigger flywheel and the cable attachment to the case for the clutch. last 4 would be sequence for the previous numbers. Bruce |
Quick Learner
Clear as mud. Lol. Thanks man. Do you have an example of a correct number? Am I missing some?
the number would be 911/01 7101747, this is a 1970 type 911 transmission, and I think the T's E's and S's all had the same gearing? The tech book doesn't designate between them just the model years they were used in, 1970 and '71. Hope this helps a little.
'73 914 2.0L |
Quick Learner
Thanks! That does help! Does it mention the gearing?
gearhead
901/13 gear question
Here's an old thread with what you need to know. Let me know if there's anything else I can do to help.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Quick Learner
Awesome! Thanks Matt! Where is Ghetto Garage CO? I am in Parker...
