Fuel Distributor Stopper
Does anyone know of an alternative to the USD ~$60 fuel distributor stopper for a 1980 911 SC? The ~$60 price for a piece of wire with a small blob of rubber on the end just seems excessive.
So, I'm looking for less expensive alternatives, any ideas?
Does anyone know the diameter of the access hole? I may be able to make something if I know the diameter of the hole that needs to be sealed.
Thanks!
Jason
Old 12-10-2025, 02:05 PM
I have a couple in the drawer, reasonable offer plus shipping
PM to reply.
Bruce
Old 12-10-2025, 02:08 PM
gptom's Avatar
I used a golf tee on my VW
68 Beetle 68 to 72 sold
72 911T Nov 71 to present P/U @ factory Nov 19. Car was gift to myself for surviving the army
67 VW split window 74 to 76 sold
81 VW caddy 81 to present
Old 12-11-2025, 09:29 AM
Modified Version……..
I used a golf tee and ball point pen tip for my 911 for better handling. Just kidding.
Tony
Old 12-11-2025, 10:57 AM
on your web browser / search engine, enter search string: "De Lorean 102392A"
Looks the same ; no guarantees --- good luck!
Thanks!
Jason
1983 911 SC Coupe w Sunroof, Metallic Silver --- AKA 83 Silberpfeil
Old 12-11-2025, 11:00 AM
Tony
Thank you, I've shoved a small pencil in the hole for now.
Jason
Old 12-11-2025, 11:11 AM
WOW, it sure does look the same and for $7 it's an absolute bargain!
Jason
Old 12-11-2025, 11:15 AM
PCA Member since 1988
I bought that part from Delorean a couple years ago. It fits. It's used on nearly all CIS engines across a number of manufacturers. The Delorean engine was from a Volvo.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 12-11-2025, 02:52 PM
Put a thin smear of silicone grease on the rubber plug so it is easy to slip in and out. Without some lubrication the rubber will eventually come loose from the stainless rod.
1990 928 S4
1998 Boxster
1978 911SC coupe
Old 12-11-2025, 06:18 PM
Schulisco's Avatar
It's a simple plug only and only a cosmetical thing. There is no functional need for it, as it's placed in front of the sensor plate and the air going through that hole is measured too. So this is no vacuum leak aka false air. The technical benefit is preventing clogging the hole by dust. That hole is standard for CIS sensor plate housings of many cars. So you can grab one also from Volkswagen classic parts too: Part no. 035 133 465, used on VW Rabbit/Golf/Scirocco Mk 1:
https://www.volkswagen-classic-parts.com/catalog/de_de/part/035133465
The hole in the sensor plate housing is 7mm wide. Plug is 80mm long.
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL.
Old 12-12-2025, 06:39 AM
Originally Posted by Schulisco View Post
It's a simple plug only and only a cosmetical thing. There is no functional need for it, ...
It appears to me that the stopper prevents unfiltered air from being sucked in to the combustion chamber. Or have I misinterpreted something?
Jason
Old 12-12-2025, 12:12 PM
E Sully's Avatar
You are correct BOPE. It will not affect metering of the air, but allow some unfiltered air in.
Ed
1973.5 T
Old 12-12-2025, 03:04 PM
Schulisco's Avatar
That amount of unfiltered air is that low, so it's neglectable. Or how do you explain that thousands of CIS cars running without these plugs with absolutely no issues because of that?? Mine haven't had this plug too when I purchased the car ten years ago and I don't want to suspect how many years it was running without it. From factory they had a breakaway screw instead. I seriously doubt that any mechanic replaced that screw by this plug anytime they tinkered that screw setting although they should not do this. But due to vacuum leaks on the engine they started to fiddle around without any knowledge and screwed up the setup of the CIS without solving the real issue(s)...
Old 12-12-2025, 05:38 PM
Thomas, yeah most of the CIS cars probably don't have this plug, but it's still good mechanical practice. I live 1/2 mile up a gravel road, and it gets really dusty in the summer, so in my case, it could cause accelerated engine wear.
Old 12-13-2025, 12:17 AM
Schulisco's Avatar
PeteKz, I totally agree... The more dusty roads the more such minor things make the difference.... Never tested how much air being sucked there when missing the plug, but still I won't expect that much. The main airflow comes over the filter and airbox and won't touch that area where the hole is located as the venturi effect will make that much difference.
Old 12-13-2025, 05:59 AM
E Sully's Avatar
Most air flow will come through the air box, but over time enough will get sucked through to gum things up a bit. The hole is right over the main points of the system. I've cleaned up a couple. I don't want any crud and moisture building up internally to gum up the carefully balanced plate, and especially the fuel distributor piston.
Ed
1973.5 T
Old 12-13-2025, 06:27 AM
