Quick Learner
levdeb's Avatar
My transmission... what is it?
Hey all!
Had a fellow Pelican visit today and help figure out my project. He said to post the numbers off the bottom of my transmission when I got it apart, and I would find out what it is, and if its any good...
So, here is what I have:
911 0 7101747
There may be another "1" after the first 0, but it looks like someone hit a rock or something, so couldn't be sure.
Thanks!!!
Old 08-22-2009, 05:13 PM
probably should look like this..
911/01 Then the next couple numbers should tell you 4 speed/5speed, T, E, or S
should be a 70/71 901 trans with the designation 911 for the bigger flywheel and the cable attachment to the case for the clutch. last 4 would be sequence for the previous numbers.
Bruce
Old 08-22-2009, 07:28 PM
Quick Learner
levdeb's Avatar
Clear as mud. Lol. Thanks man. Do you have an example of a correct number? Am I missing some?
Old 08-22-2009, 10:02 PM
Kevins911's Avatar
the number would be 911/01 7101747, this is a 1970 type 911 transmission, and I think the T's E's and S's all had the same gearing? The tech book doesn't designate between them just the model years they were used in, 1970 and '71. Hope this helps a little.
'73 914 2.0L
Old 08-22-2009, 10:16 PM
Quick Learner
levdeb's Avatar
Thanks! That does help! Does it mention the gearing?
Old 08-23-2009, 06:37 AM
gearhead
901/13 gear question
Here's an old thread with what you need to know. Let me know if there's anything else I can do to help.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 08-23-2009, 06:42 AM
Quick Learner
levdeb's Avatar
Awesome! Thanks Matt! Where is Ghetto Garage CO? I am in Parker...
Old 08-23-2009, 07:48 AM
