-   -   How do I remove the knee pad in my 964/965 (http://forums.pelicanparts.com/porsche-911-technical-forum/494375-how-do-i-remove-knee-pad-my-964-965-a.html)
sri 08-26-2009 06:30 AM
I have a 94 911Turbo(965) and I need ti remove the knee pad to properly remove some wiring for an aftermarket alarm that was installed by a previous owner. I have removed the 10mm bolts( 2 each) that are found on both ends and also removed the two 10 mm bolts found under the ashtray but the knee pad is still not moving what am I missing here?
sri 08-26-2009 07:00 PM
I figured it out, Since no one here replied I thought I will post it. The climate control and the radio need to be removed. There are 8mm bolt under each one and off it comes.
Sri
