deathpunk dan's Avatar
Can broken Tachometers be repaired??
Hello
My car's tach was dead when I bought it, so I bought a used one and swapped it in. It worked for awhile, but then the voltage regulator went. Replaced the VR and shortly thereafter the tach started working erratically then finally not at all. Guessing the VR failing was the cause of its demise.
So now I have 2 non functioning tachs. Can they be fixed or are they junk once they are fried?
Dan
Sepia brown 1971 911T.
Old 08-28-2009, 08:39 AM
scottb's Avatar
IF the problem is the actual tach units, I'm sure a place like North Hollywood Speedo can repair them for you.
http://www.nhspeedometer.com/
1984 Targa
Old 08-28-2009, 08:48 AM
19 years and 17k posts...
azasadny's Avatar
I sent my tachometer and speedometer to North Hollywood a few years ago and they did a great job! No problems since...
Art Zasadny
Learning the bass guitar
www.ford.com
Old 08-28-2009, 09:09 AM
Pelican Parts can rebuild your tach. I just sent mine to them. They said it usually costs $150-$200.
http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=RE-GAUGE&catalog_description=Pelican%20Gauge%20Rebuild%20Pr ogram%20-%20Speedometer,%20Tachometer,%20Clock,%20etc...%20
This is the email I got when I inquired:
from Glenn at Pelican Parts
to Grant Early
date Tue, Aug 4, 2009 at 8:44 AM
subject RE: Gauge Rebuild Program Inquiry
mailed-by pelicanparts.com
hide details Aug 4
Hi Grant, yes just ship it to us and put a note inside the box explaining the problem, your contact information and also if you want to be informed of the cost before the repair is made. Then we'll give your gauge to our tech who will open it up and see what's wrong and give us an estimate that we can forward to you.
If you decide to have us do that, you can send the gauge to us at; Pelican Parts, Attn: Gauge Repair, 120 Standard Street, El Segundo, CA 90245
Glenn Sager
Sales Associate
888 280-7799 x240
pelicanparts.com
Old 08-28-2009, 10:34 AM
