So my car stopped turning to the right...
And it turns out I want to drive to places on the right.
But seriously, my steering was feelin sketchy for a while, sticking and binding a bit every now and then. Now it wont turn to the right at all... Where should I start, is this something I should try to fix myself? Any help would be great.
Oh, its a 76 912E.. i posted it here because the steering is more 911 than 912?
Old 09-05-2009, 07:34 PM
Information Junky
island911's Avatar
Always going Left, eh? Are you sure that this post doesn't belong in the political forum?
My guess would be the rack & pinion has a problem. But first just get a good look under there for any foreign bodies or loose parts causing a bind.
Old 09-05-2009, 08:50 PM
78 in a '71
mossguy's Avatar
Not PARF..... NASCAR!
Best,
Tom
On glide path......
1971 911 T Targa
2013 Ford Fusion Titanium AWD
Old 09-05-2009, 09:02 PM
Mitch Leland's Avatar
If you want to do some trouble shooting I would start by putting the car up on jack stands and taking off the front wheels so you can look around. If it's a real hard binding or stop then I doubt it's in the upper steering column bearing. Plus that would probably bind equally in both directions.
I think with the front end unweighted you might be able to see or hear the problem. Get a second person to work the steering wheel while you put your eyes and ears to different areas of the front end.
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 09-05-2009, 09:37 PM
Formerly known as Syzygy
Canada Kev's Avatar
Foreign bodies? You mean like Canadians?
Kevin
Old 09-05-2009, 10:12 PM
Could also be the steering lock on the ignition switch.
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 09-06-2009, 03:13 PM
Thanks, Ill try that.
Old 09-06-2009, 08:56 PM
