Muffler Recommendation for a 3.2
Greetings,
I have a stock 3.2 in my 85. I recently added a Steve Wong chip, which made a very nice improvement. A few friends/members in my local PCA suggested I upgrade to SSI's and a sport muffler. At the present time, I'm not ready to make the investment for both SSI's and muffler, but I wanted to know if upgrading to a sport muffler only would make a difference. If so, what type of sport muffler should I consider? Thanks.
Scott ___________________________ 1985 Carrera Targa - Guards Red 2006 Acura TSX Navigation - Milano Red |
Here are some great threads that will answer most of your questions plus some you haven't even thought of yet.
![]() http://forums.pelicanparts.com/search.php?searchid=4283154
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Northern Motorhead
I also installed a Steve Wong chip in my stock 89 Coupe... along with a Fabspeed one in two out exaust and a MK cat bypass/Euro mufler!
Great looks and the sound is very acceptable,although this system is high quality so expect to pay more than the lesser brands... By the way,it sounds awesome at the 6750 RPM redline
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
I vote for an M&K. When I had my 84, it had a SW chip, test pipe and M&K muffler. Adding the M&K to the test pipe and chip added good seat of the pants hp. Probably just the sound that made the car feel faster, but every little bit helps.
Tru6 Restoration & Design |
From what I've read tonight about mufflers, M&K seems to be at the top of the list for many folks. But there are so many choices for my 85. 1->2, 1->1, 2->2, 2->1, what are the main differences and what will give me the most "bang for the buck" - horsepower-wise?
You will need an M+K 1inlet muffler as you still have the factory catalytic convertor or a bypass which means you have 1 inlet.
Dual outlets will be a bit louder and will require cutting your rear valance for the extra tip. Here are the samplings of M+K that you can get right here at Pelican. http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_EXHmuf_pg3.htm#item7 Unless you change to headers or factory heat exchangers from 69-73 you will probably not see much HP gain in just a muffler. It'll sound like you added 100 HP, though!!
Im running FABSPEED and loving the sound. Really comes alive in the upper RPM's
Rob G |
more PM's than Posts
+1 for a M&K and a cat delete
I have borla for turbo, modified to fit my non-turbo. I love the sound, best sounding I've ever had.
Fat butt 911, 1987 |
abides.
Having just gone through this...
Buy a fabspeed or M&K cat bypass and a single outlet sport muffler. There are more cost effective improvements for 3.2s than SSIs. I believe Steve Wong's data supports this. SSIs: $1150 Sport muffler (M&K, Monty, Dansk): $650-1000 Oil lines: $225 Hardware: $50 A carefully spent $2,000 could get you some very nice suspension upgrades.
Graham 1984 Carrera Targa |
M&K is a very popular choice and great customer care.
If you want a muffer that looks more stock you might look in to the Dansk sport muffler. As to HP, adding a sport muffler on top of a cat bypass is maybe another 3-5hp if I recall. I prefer not to stand out in town anymore than necessary when I get on it so I have stayed with the stock muffler with a chip and cat bypass. The stock muffler is a pretty good and effecent muffler. |
I have a M&K and cat bypass....its loud.....but I love it
Don Booth 87 Carrera Coupe (Current) 70 911 T Coupe 74 914 |
