after sitting 3mo's, clutch will not disengage... any ideas
I am hoping someone can miraculously save me from dropping the engine on my '73 RS, here's the situation...
We had the engine out for some cosmetics and a fuel pump rebuild, got everything back together successfully and the car was running and operating fine once we tuned the pump. We even put it on a local dyno to check the fuel pump set up and got very respectable numbers.
Drove the car a few times with no complaints. Then the car sat for about 3 months.
When I recently tried to drive it he was unable to get the transmission into gear, grinding noises. I had a quick look under the car today. The clutch cable moves, the actuating arm(?) moves. With the engine not running the trans can be put in gear. With the engine not running and the car in first gear, when I manually turn the wheels I saw no movement of the flywheel... but I don't think that is even possible? I was just looking at what I presume is the flywheel through a tiny hole at the bottom of the mating surfaces between the engine and trans.
The car can be started in gear, if it is, the wheels will turn whether ther clutch is engaged or disengaged. Also, with the car running, in gear, with the clutch DISengaged (clutch pedal to the floor) applying the brakes will slow the engine rpm.
So, any ideas? I am fully capable of putting things together incorrectly, but the fact that the car ran without complaint for a while kind of points away from that. I am thinking possibly that the driven plate is frozen to the flywheel/input shaft splines? If so, I know it is not from rust... or really sitting for an extended period... any way to break it free and avoid dropping the engine and/or trans? Otherwise I am thinking release bearing circlip/throwout shaft splines.... back the lack of any previous indication of a problem is not pointing in that direction, to me anyway.
Any help/info/insight you can offer will be greatly appreciated.
Old 09-03-2009, 07:35 AM
Flyin Brian's Avatar
The clutch is likely rusted to the flywheel surface... happens in my race car. Here is a simple fix.
1) With the car off, place it in 2nd gear
2) Attached the car with a tow-strap to a 4-wheeler or SUV
3) Get in the car
4) Depress the clutch, leaving the car in 2nd
5) Have a buddy tow you SLOWLY
6) "Bump" the clutch in and out, not the full length of the travel, until you feel it release
7) The clutch should break free.
Let us know if this works, there is another solution, but it is harder to acheive and risker to your engine.
Flyin Brian
'74 RSR Clone and Vintage Racer
Old 09-03-2009, 07:52 AM
evill's Avatar
you could also try putting the car in 5th gear, press in the clutch and try to start it. I have done this before, the torque of the starter and engine can break the clutch disc free of the flywheel.
Ed
Basically, I'm One Giant Train Wreck.
http://community.webshots.com/user/evill914
Old 09-03-2009, 09:57 AM
jkh2cpu's Avatar
On the floorboard is that pesky clutch stop. That did not move on you, did it? If it slipped a very little, it could keep the clutch from disengaging.
HTH
John
Original Owner 1973 911T. Webers, SSI, SAW & Polybronze, Carrera chain tensioners, 'A' calipers
Old 09-03-2009, 11:25 AM
aj88cab's Avatar
And yet one more option...put the rear up on jack stands, press clutch, start the car, if that alone doesn't break it loose, hit the brakes (with clutch still pressed).
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 09-03-2009, 12:52 PM
thanks for all the input guys... I will try your suggestions tomorrow...
Old 09-03-2009, 01:43 PM
charlesbahn's Avatar
I had that happen, just let the car sit a run for a while, pushed the pedal a few times. Just the heat and vibration set it free. Was sitting in the car when it let go, kind of a whooomp and shudder and then all was well. A Porsche orgasm.
Charles
Old 09-03-2009, 03:36 PM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Charles
Wouldn't that be a Porschasm?
eric
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 09-03-2009, 04:54 PM
ruf-porsche's Avatar
Charles
You must have felt relief when the clutch let go. LOL
Old 09-03-2009, 05:03 PM
update... got the clutch to disengage this morning.
started it in first on jackstands, high idle , stabbed the brake pedal a few times... no luck
tried again in fifth... no apparent luck
shut the car down... and in preparation for the third attempt... aaahhh, sweet relief
I guess the build up was just too much, she let go before we even had a chance to start her up the third time.
now I need a smoke and a nap
thanks guys
Old 09-04-2009, 05:54 AM
