How to remove wire connectors
Can anyone help as to how to remove the 3 wire connectors from the headlight receptical in the headlight bucket of an SC??
I need to remove the fenders and this receprical will not fit through the hole in the fenders headlight bucket. Thanks, Bob ps... if I have to I can cut apart the receptical and order new ones IF they are avail, but there must be some way to get em' out... |
If you look inside the connector closely you will see that the little spade connector inside has a tab on it that is holding the spade inside the plastic peice. You need to flatten this little tab. A very narrow and thin screwdriver will work. I had to grind an old screwdriver down to size.The srewdriver fits between the spade connector and the plastic cover.
http://forums.pelicanparts.com/uploa...1252033351.jpg
use one of these tool usually at Harbor freight Lorne M. |
thx guys... I thought sticking in somthing thin would work, but, the screw driver I used was probably too fat & I needed to put on my glasses!!
Cool... another tool to buy... I guess te pictured multi head tools are for all of the different type of connectors that need different types of insertion relief to seperate the connectors... Thanks again guys! Bob |
| All times are GMT -8. The time now is 03:08 PM. |
