-   -   How to get some power out of an 81 SC and a couple other questions... (http://forums.pelicanparts.com/porsche-911-technical-forum/496477-how-get-some-power-out-81-sc-couple-other-questions.html)
UrQuattro 09-07-2009 06:32 PM
Yah. I just doublechecked. The emissions sticker says that itmeets all EPA and CA emmissions standards for the year 1981.
Damn. For a second i thought maybe I made a bad assumption
deathpunk dan 09-07-2009 06:43 PM
You know I was kidding about the 'all wheel drive scirocco' comment, right? SmileWavy
UrQuattro 09-07-2009 06:47 PM
Hehe duh. I thought I'd get yah back with some sweet sweet paranoia.
fred cook 09-07-2009 06:47 PM
More Hp................
Since you have to keep the engine looking like a stock setup, that eliminates the easy choices. How 'bout adding a nitrous oxide setup? If installed carefully you could hide the engine pieces behind the CIS and still get a major "kick" when you wanted it.
Good luck on your project!
gsmith660 09-07-2009 06:51 PM
You could go with the Bitz EFI kit http://bitzracing.com/ take a look at the website it can be installed such that it will pass for stock to even the trained eye to a certain extent and the reported hp increase for a 3.0l is 23 hp on the dyno.
jimbauman 09-07-2009 07:16 PM
Strip it! Lose the A/C, all the junk-in-the-trunk, 964 cams (and while you're at it, RSR seals on your rocker shafts just because), cat bypass (except for a week every 2 years), flowmaster muffler (lighter than the stock banana slug). Then for fun, 23/28mm torsion bars, solid engine and tranny mounts, WEVO shifter, strut brace, turbo tie rods, Bilstein sport shocks in the rear, Koni adjustables in the front, harder bushings.... You should be happy with the go-kart like feeling when you're done.
JB
911st 09-07-2009 09:40 PM
Put a cat bypass pipe on it and a sport muffer. Tune it and put it on a dyno to check the Air Fuel Ratios. You can put the cat back on for SMOG time very two years.
SC's with a good suspention, tires, and a little lightening can be extreamly fast on the track. Never going to be much of a drag racer.
