peppy's Avatar
Fan housing cracks
I have searched the fan housing threads and it seems there is still no cheap fix for this.
Have the ones that had theirs welded held up well?
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
1982 Chevette Diesel SOLD
Old 09-04-2009, 04:50 PM
grateful user
don gilbert's Avatar
lets see pics of the cracks, might not be as bad as you think.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 09-04-2009, 05:15 PM
DUK DUK is offline
DUK's Avatar
I know it's sacriligious, but consider a ******. I've been really happy with mine.
But first post pics of your cracks and let the experts have an opinion.
75 911 Indian Red- RUFWAN2B 2000 Boxster
2000 & 2007 Dobies
www.stahlwerks.com Cages and preparation for your Porsche
“People who never make mistakes must get tired of doing nothing”
Bill : The origin of the orgy of Porsche
Old 09-04-2009, 05:20 PM
peppy's Avatar
I will try to get pics up tomorrow.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
Old 09-04-2009, 06:21 PM
Last couple I paid attention to including the 3.2 build im doing now, looks like there is too much tightness on the fan belt with the top reinforcement cracked.
Well, we can put some dope on the one and there is still 3 left to support the alternator...
Bruce
Old 09-04-2009, 07:43 PM
Son of a Son of a Sailor
Looking_for_911's Avatar
Along these lines.....
There is a slight rubbed place on the inside bottom of my fan housing. I suspected that I may need to replace the unit, but before I did that I painted over the scrape with some touch up paint with the thought that the scrape could have been an old wound that the PO had addressed some way. I have since driven the car spiritedly and the touch up paint has not been rubbed off the housing.
Does this mean the housing is ok because the fan isn't hitting it and rubbing the paint away? I hope so. But I'm not sure and that worries me.
Old 09-04-2009, 09:11 PM
peppy's Avatar
Here are the pictures. The cracks don't look as bad today as I thought they were yesterday.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
Old 09-05-2009, 07:23 AM
Somatic Negative Optimist
Gunter's Avatar
I fixed a few like that with JB Weld.
You'll need to use a Pencil Grinder like a Dremel.
Use a small bit with a rounded front tip.
Carefully grind into and along the crack to clean out and expose new metal.
Apply JB Weld per instructions and let dry.
Don't overtighten the housing strap and fan belt tension.
If you're concerned about the belt slipping, apply a little belt dressing.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 09-05-2009, 08:23 AM
peppy's Avatar
Thanks doc, that is what I wanted to hear.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
Old 09-05-2009, 11:03 AM
