distributor rotor question
what piece is the "front" of the rotor on an early Bosch distributor (008)? Is it the black metal tip sticking up? what am I supposed to be pointing at #1?
Sean 1982 SC D-Stock #372 NASA GTS2 1971T restoration in progress, read about it here: http://911restorationmadness.blogspot.com/ |
sfoster13,
Is this the rotor that you have?
Rex 1975 911s and 2012 Range Rover Sport HSE 1995 BMW R1100RS, 1948 Harley FL |
yes
Static Time
The picture above is static timed at #1 firing position... That notch might be aligned around the clock in some other configuration, but it will always be just right of one of the cap clamps.. That is a rev limiting rotor, Check the bottom side of it for the rev at which it cuts out the ignition. The slide tab moves out and ground against the tab at about 6 oclock in the picture to kill the ignition..
Bob
SWB 911S 1967 307653S in my fathers garage now LWB 911T 1971 9111120264 Back in my garage after a lenghty stay in Oregon |
thanks guys, that explains some problems I've been having
Is it running now?
Gary R. |
Bland
Related question... will a 70 - 73 S rotor fit a 74-77 dist? I want the 7300 rpm redline instead of 6500 rpm now that my engine is broken in.
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
just can't get this thing running. done everything by the book and no dice. any ideas? what else should I check for on the distributor? came from a running car (so I was told).
Does it run now when you put the Marelli back in or is it totally dead?
Gary R. |
Is the distributor 180 degrees off? It's easy to do.
Tried rotating the Bosch 180 degrees without luck.
