72' 911S
Turn Signal Housings
Hello -
I've got a 72' 911T, and I cannot get anything in the driver side front and rear turn signal housings to work. Nothing lights up, no brakes, no reverse, no turn signals. Can anyone give me a good starting point for investigation? Thanks in advance! |
Make sure you ground wires are connected very well.
Registered knucklehead
Check fuses as the drivers and passengers sides are on different fuses..
Gregg
1983 911 SC Cabriolet, 1989 944 S2 1969 Chevelle SS396 w/427 Vette motor, 1970 Buick GS455 2000 BMW 528i Touring, 2005 GMC Sierra |
Check any through-the-sheetmetal connectors, usually round plug-like connectors. For all the lights in two separate lighting units to be dead is suspcision for a common fault--though that does not discount the separate fuses.
If your reverse and brake lights work on the right side but not the left, then it's not the fuse as both sides share the same curcuit. That does not hold for the turn lights and parking lights, so that could be a fuse. You may have two separate problems, but checking fuses is definitely top on the list.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip Last edited by ossiblue; 09-09-2009 at 06:20 PM.. |
Information Junky
Sounds like a bad ground. (brown wire)
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
