lava
lava's Avatar
Porsche Crest Rennline adjust. gas pedal
I have a new Rennline adjustable gas pedal, with the pedal covers for the clutch and break. If anyone has put these on their car I'd welcome advice.
1987 GP white Carrera
Old 09-09-2009, 02:28 PM
David in VA's Avatar
I found that it helped a lot to remove the stock gas pedal and then attach the rennline one on a workbench. Two bolts and pull to remove from the rod it's connected to. The brake and clutch pedals are pretty straightforward, remove covers, drill holes and bolt on. Here is a shot of the ones I have.
'87 911 Coupe
'95 911 Coupe
'04 911 GT3
'98 Jeep Wrangler
Old 09-09-2009, 02:39 PM
zugelassener benutzer
teamfee3's Avatar
Rennline
You'll probably need to shorten the rod 1/4" + but very simple install. I had to get used to having my foot sitting a little more upright. Really nice set up though.
Team Fee '86 Carrera 3.2 Coupe blk/blk, no wing
7&9x16s BFG GForce SS 205/55 & 245/50s, SW Chip, Maxspeed catbypass, B&B, Sachs Power Clutch, Turbo mounts, oil cooler scoop, RS door panels, Momo Prototipo, Rennline fully adj gas pedal & floorboard, RS replica dead pedal, Weltmeister yellow h/l lenses, factory short shift, custom speedo
32C #7
Old 09-09-2009, 03:12 PM
