Cutaway diagram of engine?
Well, I posted this in the wrong forum, maybe (engine rebuild).
Can someone point me to a cutaway diagram that would help me better understand the inner workings of the flat six?
Many thanks,
Jack
Bassjack
85 911 Targa
Old 09-09-2009, 03:57 PM
Senior Advisor
James Brown's Avatar
theres a cool animated cutaway of the engine running somewhere on this forum, can't remember where.
08 Cayenne Turbo
Old 09-09-2009, 04:00 PM
zugelassener benutzer
teamfee3's Avatar
Team Fee '86 Carrera 3.2 Coupe blk/blk, no wing
7&9x16s BFG GForce SS 205/55 & 245/50s, SW Chip, Maxspeed catbypass, B&B, Sachs Power Clutch, Turbo mounts, oil cooler scoop, RS door panels, Momo Prototipo, Rennline fully adj gas pedal & floorboard, RS replica dead pedal, Weltmeister yellow h/l lenses, factory short shift, custom speedo
32C #7
Old 09-09-2009, 04:22 PM
80-911SC's Avatar
i think its also lelands avitar but dont remember were else
Old 09-09-2009, 05:13 PM
Cool
Old 09-09-2009, 06:37 PM
Porsche Crest
Arrow
Old 09-09-2009, 06:39 PM
Old 09-09-2009, 06:42 PM
Thanks Guys...you're educating me with every reply! Jack
Bassjack
85 911 Targa
Old 09-09-2009, 08:49 PM
Senior Advisor
hey, that thing got a HEMI?
08 Cayenne Turbo
Old 09-09-2009, 09:46 PM
sc_rufctr's Avatar
Do you mean the shape of the piston top in the gif file?
Peter
Old 09-10-2009, 01:22 AM
proffighter's Avatar
As far as I know, Hemi means the layout of the combustion chamber :
hemispherically-shaped
Piston shape is not relevant (at least namely)
Roland
930 Turbo '81 Too many modifications to list
Old 09-10-2009, 03:44 AM
sc_rufctr's Avatar
OK... But the piston has to fit into that shape.
Peter
Old 09-10-2009, 04:31 AM
It is beneficial, when the piston fit's into the chamber
Seriously, turbo engines got flat pistons, non aspirated ones are like shown above. It's a question of the compression ratio.
Modern turbo engines got higher ratios today and so layout is more equal.
What you can't see on the pic, is that the room left, when piston is on TDC, is where the spark plug is located. This way pressure of combustion increases more and earlier than using a flat piston.
Roland
Old 09-10-2009, 05:57 AM
Non Compos Mentis
Yes, the 911 has a "Hemi"-spherical design, as do several other engines. Chrysler was just the best at using a relatively common engineering concept as a marketing tool.
Old 09-10-2009, 07:06 AM
Bill Verburg's Avatar
Lots of different piston dome shapes have been used in 911 engines over the years, depends on cams, induction, cr and legal constraints on emmisions
Early 89mm race piston, high dome for compression w/ large valve pockets
95mm, 8.5:1 cis emission pistons, w/ large swirl pocket
90mm 2.7RS, 8.5,
92mm bb hc piston
Flat top 930
993 100mm 3.6 emissions piston
2.7RS, 2.4T, 2.2S
3.8RS, 2.7RS
Bill Verburg
Old 09-10-2009, 08:00 AM
DP935 member
kycarguy 935's Avatar
Very good information Bill. Thanks for posting.
Porsche Slantnose M505 M506 group on Facebook.
https://www.facebook.com/groups/719995181372494/
Old 09-10-2009, 12:28 PM
ShakinJoe's Avatar
pm
'87 Carrera - 2400 lbs of Track Beast!!
'88 Carrera Cab - Too nice for the track.
'85 Targa - Salvage title that was not caught!
Old 09-10-2009, 04:13 PM
